Mostly, chipped CCMT0604 bits are used with the unused 100 degree corners for roughing. (Andrew would like the blue stuff coming off). Hundred thou cuts can make it chatter.
The original tips are used in a Boring bar. So the angles are already chosen. For most of the other straightforward turning, the Diamond (Tangential ) tool is used. Freshly sharpened, (Boasting!) it will take a cut of 0.0005 inch, or much greater. With a 1/4 toolbit have never exceeded a 0.050" cut.
The HSS parting tool, ( Secondhand when I got it, at least thirty years ago, and still nowhere near worn out) is inverted in the rear toolpost has zero top rake, and gives few problems.
On the RF25 Mill/Drill with HSS cutters, rarely exceed 0.050" depth of cut.
So am looking for fresh types of cheese.
Edited By Howard Lewis on 14/08/2018 14:16:14
