26tpi being rather close to M1.0 I reckon M1.0 would screw up to 10 or so turns into a 26tpi fitting before jamming. Might be 'good enough'?
A while ago I wrote a program to calculate gear combinations for the WM280 Imperial with the gear set [20, 25, 30, 40, 45, 50, 55, 60, 63, 70, 75, 80, 80]. Assuming I got the maths right (ahem), the closest the lathe can get is 26.25 or 2 x 13.09 tpi. I don't know if other gears have ever been available for the machine.
Interestingly, my Metric WM280 gets closer to 26tpi than the Imperial does. It has the set [ 20, 30, 45, 50, 60, 60, 65, 70, 75, 80, 85 ]. Apart from M1.0, the metric machine can also do 13.03 and 25.99
Found this in a blog about Bicycle threads on the Park Tool Website:
The bicycle industry has a long history of using many different thread standards. Both factional and metric sizes are in use. Some threads are also used almost exclusively in the bicycle industry. Below is a table of some of the threads and their uses. This table is not intended to be complete and exhaustive. Always measure diameter and pitch when possible to determine threading.
Nominal Thread Size
Example of Bicycle Uses
2.2mm x 56 tpi
Common 2mm spoke threading
3mm x 0.5mm
Dropout adjustment screws, some derailleur hardware, accessory hardware
4mm x 0.7mm
Some derailleur limit screws (DIN standard)
4mm x 0.75mm
Common derailleur limit screw (JIS standard)
5mm x 0.8mm
Many uses on bicycles, including derailleur wire pinch bolts/nuts, disc rotor mounting bolts, fender and racks mounts, water bottle cage bolts, and others
6mm x 1mm
Many uses on bicycles, including brake caliper mounting bolts, brake pad bolts/nuts, some fender racks, some brake adjusting barrels
7mm x 1mm
Some handlebar binder bolts
5/16 inch x 24 tpi
Front hubs, solid axle, less expensive bikes
8mm x 1mm
Square-type crank bolts, front solid axle hubs, suspension system hardware
8mm x 1.25mm
Stem hardware, stud type crank nuts, suspension hardware
8mm x 0.75mm
Chainring bolt
9mm x 1mm
Front hubs, quick release, Asian manufacturer
9mm x 26 tpi
Front hubs, Campagnolo®
3/8 inch x 24 tpi
Some solid axle bike, including coaster brake
3/8 inch x 26 tpi
Solid rear axle
10mm x 1mm
Most quick release rear axles, derailleur mounting bolts, brake lever adjusting barrels
10mm x 26 tpi
Rear axle, quick release, Campganolo®
12mm x 1mm
Some spline crankset bolts
1/2 inch x 20 tpi
Pedal threads, one-piece cranks
9/16 inch x 20 tpi
Pedal threads- common three piece cranks
14mm x 1mm
Oversized frestyle axles
15mm x 1mm
Crank bolt, Octalink® and ISIS Drive®
1-inch x 24 tpi
Threaded headsets, one-inch standard
1-1/8 inch x 26 tpi
Thread headset, 1-1/8 inch standard
1-1/4 inch x 26 tpi
Thread headset, 1-1/4 inch standard
1.37 inch x 24 tpi
Bottom brackets, ISO/English/BSC, and threaded freewheel hubs
1-3/8 inch x 26 tpi
Bottom brackets, older “Raleigh” three speeds
36mm x 24 tpi
“Italian” threaded bottom brackets
47mm x 1mm
T47 threaded bottom brackets
From the variety in the table it seems that bike repairers need a metric lathe than can also do 24tpi, 26tpi and 56tpi. It's another shambles!
PS Sorry about the formatting!
Edited By
