Posted by Neil Wyatt on 10/01/2018 09:27:19:
Posted by Martin 100 on 09/01/2018 22:39:26:
The mill is much more sensitive to rotational speeds and while you can wing it, without a tacho you are just guessing. I'd class it as essential.
Just to be mischievous… how do you know the right speed before you select it?
Using a very big book from Sandvik with lots of formulae in it , spinning the spindle up and tweaking the pot to somewhere towards the bottom of the recommended range.
I can get the CNC mill working fine with quite acceptable rates of metal removal, surface finish, dimensional accuracy and cutter life. But then it's not me it's the machine.
A lot of my difficulty manual milling stems I think from my height and the lack of it on the X3 with the factory supplied stand, giving a very restricted view of the cutting action compared to turning on a lathe (my brace of Boxfords despite being early 1950's and early 1960's have the chunky 80's era yellow chuck guard affording very good visibility) I can, from sight of the swarf and feel through the handwheels know if the feed and speed is right or not on the lathe I very rarely get that when milling. At least with the tacho on X3 I know I'm somewhere in the right area and can eliminate one variable.
Guess it comes down to experience, I've maybe a couple of magnitudes more turning than milling experience. Decades ago as a engineering trainee I was twirling handles on huge very tired mills with worn leadscrews, sloppy gibs and less than perfect HSS tooling, and despite cutting speed calculations ahead of time the results didn't always match the expectations. Since then I spent many hours being frustrated using a Boxford vertical slide and setups that were not even remotely rigid. The visibility of the cutting action is about as bad as you could ever get. The X3 was a huge improvement, but I'd prefer something at least half as big again with significantly more rigidity. A hefty multiple horsepower motor with a VFD would be useful too. I might have even bought something 'big' from Warco last year if they'd have done the Doncaster show.
