Thanks.
I couldn't get another shock now that I touched all the parts again… but I checked a few thigns anyway.
There are four earth wires connected to the headstock. One is coming from under those black plastic round blocks at the bottom. One is inside the thick black sleeve that wraps around a few wires, coming under the head on the right side of the photo (from the operator's POV). Two are coming from under the head, just under the 2nd from left in the photo.
I don't remember everything, but I think one is coming from the wall cable itself, one definitely from the electricity board on the "back" of the head (operator's PV), one from those round blocks and the last… I don't remember. Maybe from the motor itself? I'm not sure. I don't think the order matters but I installed back the same as they were before just in case.
You can see the plug itself only has two prongs… but isn't it supposed to be this way?
The wall socket is just above a table reinforcing bar, so if the plug had three prongs it actually wouldn't fit now. I have to connect it upside down. Should I change to a three prong plug and somehow manage to fit it?
Though if the shock would be from the 240V from the wall I would definitely know it… no?
Sorry I really know next to nothing about anything electric.
Edited By Nitai Levi on 02/08/2015 07:35:40
