Lathe question
Lathe question
Home › Forums › Manual machine tools › Lathe question
  • #13970
    David gatley
      @davidgatley63210
      #484288
      David gatley
        @davidgatley63210
        Hello. Does anyone happen to know what this is and what is is used for?
        Thanks in advance for any help
        #484301
        Oily Rag
          @oilyrag
          Hi David,
          It would be nice to see what you are asking the question about! If it is the single photograph in your album its a H/V rotary table, generally for use on a milling machine.
          #484302
          SteveW
            @stevew54046
            It’s a rotary table. Usually used with a milling machine to hold a workpiece and turn it by a known angle. So you could machine a curve (arc) or by turning at a regular interval a hexagon. There are a few videos on YouTube.
            #484305
            not done it yet
              @notdoneityet
              Obviously as above, but I am wondering if it has three registration surfaces – as it is pictured, the winding handle will be vertical when mounted on end. Seems unusual unless a special?
              #484309
                Seen plenty like that with just the one vertical option including the first one that I had, don't recall the hand wheel getting in the way when sticking up..
