Lathe motor
Lathe motor
Home Forums Workshop Tools and Tooling Lathe motor
  • #475397
    Eamonn Evans
      @eamonnevans48354
      I am a complete newbie never having used a lathe before. I recently purchased a used Cowells lathe on eBay. It came with a motor fitted the wrong way round and runs too fast.
      I have also just liberated a Kenwood Chef 375W motor complete with its speed controller which I would like to use to run the little lathe. Colin at Cowells tells me his motors are only 90W so 375W is plenty.
      The currently fitted motor shaft is too large to fit the required 20mm pulley without a countershaft and of course I can't make this easily without a lathe! Also this motor has a centrifugal clutch so I am told that you shouldn't mess with the speed.
      Can anyone tell me if it possible to reverse the Kenwood motor? I have bought Jim Cox's book but I am unsure.
      Eamonn Evans
        @eamonnevans48354
        Help would be appreciated.
        #475437
        John Baron
          @johnbaron31275
          Hi Eamonn,
          Yes you can, but you will have to feed it with DC !
          I would look for a more suitable motor, maybe a defunct shower pump motor, though most of these are induction motors and are usually about 1/2 Hp. They also have an electronic soft start in them. Reversing them is simply a matter of moving the mains live wire from one side to the other side of the capacitor.
          There are also some universal motor ones kicking about as well, but to reverse those you will have to swap over the brush connections. Or you could feed it with DC, which if you used a variable voltage DC supply would allow you to vary the speed as well as reverse it.
          #475445
          John Haine
            @johnhaine32865
            You can't reverse a universal (if you mean series-would commutator) motor by reversing the supply since it reverses the field in both armature and stator since the same current flows in each. Universal motors are anyway unsuitable for a lathe because they have very poor speed regulation – in theory with no load they run at infinite speed!
            Tell us more about the motor that is fitted, why can't that be reversed and its speed reduced? Photos would be good.
            The Kenwood Chefs that we have had seem to have a crude speed control that I suspect is based on some sort of centrifugal switch.
            #475478
            John Baron
              @johnbaron31275
              Hi Guys,
              The Kenwood food mixer motors change the speed by means of a stepped field winding. I don't know if the later ones use the same technique.
              As far as reversing a universal motor, I did qualify that by pointing out that you would have to run it on DC ! Or modify the wiring to the brushes if you wanted to use AC.
              #475493
              Frances IoM
                @francesiom58905
                I picked up a broken classic Kenwood mixer from the local amenity site a couple of years ago – the speed control appears to be a purely mechanical control of when the centrifugal switch operates
                #475494
                not done it yet
                  @notdoneityet
                  No possibility of turning the motor through 180 degrees to drive from the opposite direction?
                  #475495
                  Andy Carlson
                    @andycarlson18141
                    Hi Eamonn, Hope you enjoy being a Cowells owner. Not sure I can help with the motor question but it would be nice to see a photo or two of your lathe. I'm always interested to see a Cowells and it might help others to understand your motor setup.
                    #475506
                    Andy Carlson
                      @andycarlson18141
                      Just returned from my 'ideation facility' (aka shower).
                      A slightly different answer occurred to me… could you switch to round PU belting and run it in a figure of 8 arrangement to reverse the drive direction?
                      Never tried it so others may like to comment on whether it will work, but I'm pretty sure I've seen watchmakers' lathes running round belts in a figure of 8 and as far as I can see the included angle for a vee belt pulley would run a round belt of suitable size.
                      My Cowells vee pulley grooves are about 5.25mm at the top and my Unimat belts are 4.8mm diameter. A quick check looks plausible – they sit in the groove with a respectable gap to the bottom of the vee.
                      Regards, Andy
                      #475508
                      Les Jones 1
                        @lesjones1
                        A series wound motor is a bad choice for driving a lathe as it's speed varies a lot with load. They can be reversed (Both when supplied with AC or DC.) but you need to change the internal wiring of the motor to reverse the relationship of the current through the armature and the field winding. If you supply some details of the motor that is fitted that may be a better option than the Kenwood motor.
                        Les.
                        #475703
                        Brian Morehen
                          @brianmorehen85290
                          Normal AC motors willnot work on DC Not really woth trying .
                          Regard BeeM
                          #475719
                          AdrianR
                            @adrianr18614
                            I have a Kenwood Chef 902, it has an electronic speed control with speed feedback via a magnet on the end of the motor shaft. The speed is varied by moving the whole PCB to/from the magnet. If yours is like that you would have to work out to extend the speed control knob to where you can reach it.
                            It should be possible to reverse the motor if it is the same as the 902 as the field and commutator are on separate wires.
                            This site has some pictures and the circuit diagram **LINK**
                            BTW the speed controller has a habit of failing. There are people supplying a small kit of components to fix the PCB. The kit I got from ebay also had new brushes too.
                            Adrian
                            Edited By AdrianR on 28/05/2020 18:54:22
