Lathe mandrel bearing replacement
Home Forums Manual machine tools Lathe mandrel bearing replacement
  • #14037
    Alan Hopwood
      @alanhopwood63369
      Help needed
      Alan Hopwood
        @alanhopwood63369
        Has any member any experience of changing the Timkin bearings on a Harrison L15 lathe? I've had the impression recently that I'm getting a bit of rough running from what has been a very good lathe. I tried to take up any play by adjusting the split collar at the rear of the mandrel. but this has not cured the suspicion of a grumble (particularly when parting off). so I have obtained a pair of new bearings. The problems are that the manual which M/s Harrison have kindly supplied are copies of old items and the drawings are very hard to read.
        Any clues would be gratefully received. as it may save a lot of engineering / agricultural language being used.
        Thanks in anticipation,
        Alan.
        #499422
        Ady1
          @ady1
          I think these are L13 pictures, but may help?
