Sorry this is a bit long
Referring back to my question about cutting a groove.. that was a 12mm thick hot rolled plate 115mm x 75mm with the circle centre 30mm from long edge and central with the groove width 8.5mm.
To hold it I used the 4-jaw and reversed two jaws, sat it on the highest jaw flat and ten centred and bumped it until a DTI showed it lying right.
My original idea was to cut the groove then bore a central concentric hole but this wally hadn;t realsied that the one reversed jaw obscured the hole centre from the viewpoint of getting a boring bar right through
I moved it to the mill and swept the groove with a dti to centralise and discovered that the groove is sl elliptical.
Now it turns out that I did have a couple fo digs during the grooving .. so it may have shifted the ite. but it also turns out that whie it ddnlt appear to be a problem at the time – somehow overnight the 4-jaw had loosened on it;s backplate – an obvious vibe i couldn't have missed unless it was way less at the time.
It;s out of round reading 0.05mm less each side of one axis sweep compared to the other.
The questions:
I didn't have any parallels that were a useful 'fit' on the chuck for levelling and i'd have run out of hands trying to centralise the part.. any tricks beyond the setting and bumping I did?
If I put a part like that on a mandrel would the imbalance be too great and if so how to balance it without clamps etc above the working face?
If I used the faceplate should it be skimmed first or just check with a dti?
It using the face plate how best to hold such an item without any holds being above the 12mm thickness?
Now I have two ideas for that.. one would be based on low blocks bolted to the faceplate and then 6 or 8mm grubscrews clamping to the edges or indeed making the plate larger with sacrificial 5/6mm rim that low clamps could hold down onto.
Lastly it occured to me that one could cut the groove on the mill either by making a new tool for the boring tower or a modified flycutter type tool with a vertical cutter specifcially for the radius wanted.to clear the heel of a boring tower tool?
