Laser alignment
Laser alignment
Home Forums Workshop Tools and Tooling Laser alignment
  • #19721
    Henry Brown
      @henrybrown95529
      Seen in an old post…
      Henry Brown
        @henrybrown95529
        I'm machining the various parts for an "Economy" engine and referring to the thread by Nick_G as I go. I was checking for something he had done as the drawing is a bit vague and noticed he had used a laser to set the base for the engine, out of curiosity I had a look on the web for something similar but couldn't find anything.
        I lined my castings out and used a scriber to set my base and hopper for machining however they will need to be brought together at some stage. Do others use the laser method?
        Picture of Nick_G's set up for reference…
        Edited By Henry Brown on 25/04/2020 13:38:03
        #467003
        KWIL
          @kwil
          I have looked at the use of lasers, but, for me the width of line is far too much, you are left with guessing the centre of the line.
          #467015
          Howard Lewis
            @howardlewis46836
            Have never used a laser to set up work, only to align the head on my round column mill/drill.
            The laser is a DIY store cheapy, but an error of the width of the line, over a distance of ten feet amounts to about a thou, which seems acceptable to me.
            #467063
            Henry Brown
              @henrybrown95529
              Cheers chaps, I'd gathered that the width of the projected line from a cheap pointer wouldn't be of much use but the better quality building products have a finer line, maybe I'll have a look at my son in law's fancy one when the lock down is over.
              I wondered if anyone recognised the one in the picture…
              Edited By Henry Brown on 25/04/2020 19:25:13
