KLG Mystery Object.
KLG Mystery Object.
Home › Forums › The Tea Room › KLG Mystery Object.
  • #567262
    peak4
      @peak4
      One for the hive mind.
      Over here in Buxton we have a market a couple of days a week, where one of the traders sells various bric-a-brac.
      Some I buy, some I try and help him identify, but this one has me stumped.
      Not the best of photos as they were grab shots on my phone.
      We know KLG were a spark plug maker, and this seems to tally with the ceramic material from which this is made.
      It's about the same size as a spark plug, but with no metallic parts.
      There is a through hole of about 3mm/1/8" as though a wire might pass through to some sort of (absent) metallic cap.
      The box is plain, with no lettering of pictures, and seems original.
      Front View
      Side View
      The longest end is forked
      Any Thoughts please
      Bill
      #36599
      peak4
        @peak4
        #567264
        Rik Shaw
          @rikshaw
          Electrical insulator.
          Rik
          #567265
          Brian Morehen
            @brianmorehen85290
            The forked end for removing the HT lead when engine is running.
            Regards Bee.M
            #567266
            Ian Johnson 1
              @ianjohnson1
              Looks like a bottle opener? One of those freebie corporate giveaways?
              IanJ
              #567267
              DC31k
                @dc31k
                Posted by Ian Johnson 1 on 18/10/2021 17:35:46:
                You are correct. See near the bottom of this page.
                A Life in a Year – 2nd November, Motorways and Minis
                #567271
                Clive Foster
                  @clivefoster55965
                  I imagine the point of the corporate giveaway was to show that Hylumina was much less brittle than porcelain or (then?) standard high voltage insulation ceramics and had significant shear strength.
                  Porcelain or standard ceramics would almost certainly break long before the bottle top came off.
                  #567273
                  old mart
                    @oldmart
                    I bought a box of ten turning inserts very cheaply on ebay and made a holder for them. They look like square white tablets, about 10mm per side and 4mm thick, much lighter than carbide. The edges are blunt, but they certainly have no trouble turning fully hardened HSS but you have to keep clear of the red hot sparks.
                    #567277
                    Ian Johnson 1
                      @ianjohnson1
                      It looks well made and strong enough to open a bottle of Guinness… or two.
                      It's one of those little workshop oddities I'm going to look out for!
                      IanJ
                      #567281
                      peak4
                        @peak4
                        Posted by DC31k on 18/10/2021 17:47:50:
                        Cheers for that, we both thought it looked like one, but assumed the material would be too brittle.
                        Bill
