Kennedy Hexacut machine hacksaw
Home Forums Help and Assistance! (Offered or Wanted) Kennedy Hexacut machine hacksaw
  • This topic has 38 replies, 17 voices, and was last updated 4 May 2025 at 18:56 by William Ayerst.
Viewing 25 posts - 1 through 25 (of 39 total)
  • #650931
    Leo F Byrne 1
      @leofbyrne1
      The belt disintegrated on my hacksaw, which has been a good and faithful servant. Tony at Lathes was very helpful and sent a belt, It kept slipping and he sent another FOC.
      Now it won't cut square. I have managed to tighten the front section with the help of Ian Jamieson – may his name be praised – but the saw won't cut square. I have fiddled about with the hexagonal guides/shim but to no avail.
      I was making 1.8 mm discs from 28 mm brass rod, grinding them flat on the disc/belt sander and then slicing them. This is to make discs for the ball dispenser at the golf club – the pro can't buy them. I then machine a slot to fit in the machine.
      I have now given up. Has a skilful person got any suggestions?
      I make all sorts, but nowadays bows for violin/viola/cello.
      Leo
      Leo F Byrne 1
        @leofbyrne1
        Problems
        #650934
        peak4
          @peak4
          In which plane does it fail to cut square, and does the cut wander part way through?
          By that I mean, does the cut go off vertically, or is the blade no longer perpendicular to the vertical face of rear vice jaw?
          I've just been out to look at mine and it seems that there is no adjustment between the vice and the hacksaw bow itself.
          I wonder if your main bearing bushes are worn, and the new belt with extra tension is pulling the man spindle, and thus the blade out of square.
          Bill
          #650939
          bernard towers
            @bernardtowers37738
            surely it must be quicker and easier to part them off.
            #650947
            Dave Halford
              @davehalford22513
              Did you change the blade at the same time? Is it still cutting on the same stroke? My 90 wandered till I used a full size power hacksaw blade, but then it is a much heavier bow.
              Half the vice is steel, but the fixed side is only the main alloy casting, is that worn just where the 28mm rod rests?
              #650950
              Clive Foster
                @clivefoster55965
                The bearings do wear, unsurprisingly, that allows things to move off line. The one we had in or little local section trials prep workshop at RARDE had noticeable rock but the saw still cut adequately. Albeit less square than we'd ideally have liked.
                Modern plastic faced belts are potential issue as there tend to need both more tension and a higher surface speed to transmit useful power. The saw was designed and developed to use a leather or leather faced fibre backed belt.
                if I had to replace the belt on one I'd change the motor pulley to poly-Vee and keep the standard flat pulley. The soft Vee side running on the big pulley will transmit enough power just fine at surprisingly low tension.
                Doesn't help that power transmission nis inherently a bit on the marginal side to so the drive slips if the blade jams up rather than break. They were designed for site work where a certain degree of careless handling is inevitable.
                #655639
                Leo F Byrne 1
                  @leofbyrne1
                  I can't part off well enough on my ML7. I am just a violin/bow maker so at the lower level of engineering ability – though I do good work on bows.
                  I think a poly-Vee belt sounds like the way to go. Current driving pulley 21.3 mm o/d, 16 mm i/d, driven pulley 150 mm o/d.
                  Can belts be had in different lengths?
                  Or should I buy a portable machine hacksaw – Scheppach – from Screwfix and put it on its stand.
                  #655657
                  vic newey
                    @vicnewey60017
                    This is just for belt slipping if you get further problems
                    Have you got the instruction booklet for it and how are you fitting the belt? You may have to loosen the two bolts near the front and pull it forward and tighten it, then put the belt on the motor pulley and then start feeding it on the big pulley and turn it as it forces the belt to follow. it will then try to move off the motor pulley so tap with a soft hammer and continue forcing the belt on, that's what the instructions say.
                    I can scan the instructions if you haven't got one
                    Edited By vic newey on 08/08/2023 17:50:32
                    #655676
                    Howard Lewis
                      @howardlewis46836
                      Assuming
                      The belt is the correct length
                      The belt is the correct section for the pulleys
                      If the belt slips, the pulley grooves may be worn, allowing the belt to slip down the groove and bottom out rather than grip on the sides of the groove.
                      And obviously, the tension needs to be correct (Again, there will will be difficulty setting the correct tension if the belt is too long, or overtight if too short.&nbsp
                      It won't help, if the bearings are worn allowing the pulley to wobble
                      Nor is it likely to cut quare, or repeatably (Not talking high precision her ) if there is play in the bearings for the actual hacksaw frame, or the guides for it.
                      If there is play in the bearings, or shaft can they be bushed, or the shaft removed and turnded down until cleans up and then make bearings to match, sat a thou or two clearnce , maximum)
                      If the guides are circular, any chance of bushing, turning down, or replacing the guides and the making suitable bushes?.
                      As each element of wear is reduced, / eliminated, so overall accuracy will improve, until it reaches a level that is acceptable..
                      Rightly or wrongly, I don't regard bandsaws or power saws as precision instruments, but properly set up in good condition, surprising accuracy can be acchieved from time to time.
                      #655683
                        I believe that the belt on the Hexacut was flat, Howard … Hence Clive Foster’s excellent suggestion.
                        Ref. __ http://www.lathes.co.uk/taylor/page2.html
                        Edited By Michael Gilligan on 08/08/2023 19:19:58
                        #655698
                        peak4
                          @peak4
                          Yes PolyVbelts are readily available in different lengths and widths, but like any other flat belt, the spindles do need to be parallel to each other to work well.
                          This is just  one of many suppliers
                          https://simplybearings.co.uk/shop/Belts-Multi-Ribbed-Poly-V-Belts/c4601_4791/index.html
                          Since Leo has an ML7, it should be easy enough to grind up a tool and make the appropriate grooves.
                          The outer circumference of the flat belt on my Hexacut is about 21½", and Simply Bearings seem to list both 20" & 21", so something should be suitable.
                          Bill
                          Edited By peak4 on 08/08/2023 20:23:48
                          Edited By peak4 on 08/08/2023 20:28:15
                          #656109
                          Graham Meek
                            @grahammeek88282
                            I recently acquired a Kennedy 60 and one of the things I have wanted to do with it is replace the rather aging drive belt.
                            I have just drawn up the pulleys and pulley centres. The belt comes out at 535 mm and the nearest to this is 533 mm or 21" , belt number 210J10. I will be placing an order shortly for this and a few other things so I will let you know how I get on.
                            Gray,
                            Unwanted graphics
                            Edited By Graham Meek on 11/08/2023 15:53:58
                            Edited By Graham Meek on 11/08/2023 15:54:47
                            Edited By Graham Meek on 11/08/2023 15:55:21
                            #656112
                            john halfpenny
                              @johnhalfpenny52803
                              How about using a poly vee belt inside out, ie driving on the flat side. I've seen this done on slightly larger machines, but the motor pulley of the Hexacut may be a problem because of the small radius?
                              #656230
                              Graham Meek
                                @grahammeek88282
                                I intend to use the Poly V on a grooved pulley on the motor, but with the ribs running on the larger pulley with no grooves. The large angle of lap should more than compensate for the lack of grooves. Further my current lathe will not swing this size of pulley.
                                The ultimate aim is to reduce the loading on the Saw bearings which wear quite considerably when using the current set-up. The other plus point is it should stop the smaller pulley from slipping. As well as stopping the belt from running off this pulley due to the above shaft mis-alignment.
                                It is possible using the Grooved motor pulley to go slightly smaller, as the minimum pulley size for this belt is 18 mm diameter. This however would mean a smaller belt and a reduced number of cutting strokes per minute.
                                The cost of this conversion as well as new Oilite bushes comes in a good deal cheaper than the replacement flat belt.
                                Gray,
                                #656623
                                Graham Meek
                                  @grahammeek88282
                                  Well despite actually measuring the saw twice and drawing things out the belt above arrived today and it is too short. Thus it is back to the drawing board and order a longer belt. When I hit the right one I will let you know.
                                  Gray,
                                  #656653
                                    Posted by Graham Meek on 12/08/2023 11:02:48:
                                    I intend to use the Poly V on a grooved pulley on the motor, but with the ribs running on the larger pulley with no grooves. The large angle of lap should more than compensate for the lack of grooves. […]
                                    Very common practice on Tumble Driers … for obvious Production-Engineering reasons
                                    Graham Meek
                                      @grahammeek88282
                                      Hi Michael,
                                      The Washing machine drive was what I had based my drive on. If it works for Hotpoint it will work for me.
                                      Gray,
                                      With regard to the drive belt I must own up to having had Brain fade. Checking the drawing again yesterday I had measured the inside of the belt and not what might be called the crest of the inverted Vee, which is 1.8 mm above the inside of the belt measurement.
                                      This dimension in round numbers is 555 mm which is 4 mm short of the next size up 559 mm or 22". This belt arrived this morning and all it requires is a slightly larger pulley at 30 mm diameter. As opposed to the original 22 mm diameter. It will mean a few more strokes per minute but I can live with this.
                                      Hopefully I can post some photographs later this week of the conversion.
                                      Gray,
                                      Edited By Graham Meek on 16/08/2023 15:13:26
                                      #656908
                                      Graham Meek
                                        @grahammeek88282
                                        Last night just before I turned in for the night. I had a sinking feeling that the new larger pulley would not fit inside the existing Kennedy Belt Guard. A quick look this morning allayed my fears. During today I have managed to manufacture and fit the new pulley and belt.
                                        I chose steel for the pulley, but with hindsight aluminium would have been better. As the Compact 5 was not impressed with the 2 mm deep Vee grooves in one hit. In the end I worked out a routine which used four cuts, two of which were off-set and formed the width of the groove at the top of the Vee.
                                        There was a bit of a setback with the Phos Bronze bearings. I think they were inserted when the main body was cast. They did not want to budge when using a puller, and the only way these are likely to come out now is by boring them out.
                                        However the saw works fine with the new belt and I have so far tested it on 25 mm Mild Steel. I did also try using an 18 TPI blade which the saw easily took in its stride. Even though the manufacturer states 24 TPI blades on the machine plate. Tomorrow I have some 40 mm square aluminium to cut up so we will see how it performs on this and maybe get some photographs.
                                        Gray,
                                        Edited By Graham Meek on 17/08/2023 19:33:28
                                        #656911
                                        DMB
                                          @dmb
                                          Gray,
                                          I once took a tatty belt to some supplier in Brighton and Hove area for a replacement and the guy produced a board with 2 pulleys mounted on it. One was moveable, allowing adjustment to make any belt fit tightly. He immediately told me what I needed by reading off Mark's on the board. Maybe a lot of suppliers use something similar.
                                          bernard towers
                                            @bernardtowers37738
                                            I remember that item in Parks Pumps in Norwich from the 60s and 70s and if I remember correctly it was made for FERODO.
                                            #656976
                                            Graham Meek
                                              @grahammeek88282
                                              Hi John, & Bernard,
                                              I have seen this type of fixture at my local bearing factors many years ago, but this was explicitly for standard Vee Belts. Not the multi-ribbed Poly V belts. Please correct me if I have got this wrong.
                                              Gray,
                                              Generally,
                                              Poly Vee belts are a whole new ball game for me. As far as I can make out the length of the Poly V belt is buried inside the thickness of the belt. For the J section belt that I used this belt length is 1.8 mm from the inner surface. At least this corresponds to what I have drawn out. I have also cross-referenced by measuring the actual, versus designed centre distances of the pulleys on the Saw after conversion. This has come out within 0.25 mm of the designed dimension. Thus I am pretty confident this is how the belts are measured. Of course I could be completely wrong and this is just a fluke.
                                              As always am prepared to learn from anyone with more knowledge on these belts.
                                              Gray,
                                              #656983
                                              Ex contributor
                                                @mgnbuk
                                                The polyvee belts used on tumble dryers are not the same construction as "standard" belts – they use a slightly elastic tension member to make the belts "stretchy"
                                                The reason I know this is that a company I worked for modified the "belt building" machines used to make the belts (by a company in Wigan) to have a closed loop tensioning arrangement to wind on the tensioning cord, which had to be applied at a specific tension to get the correct stretch required. Normal belts used a non-stretch cord.
                                                The stretchability may have been to enable the removal of a separate tensioning mechanism ( engineering by accountants ! ) & the installed tension was high. Tumble dryer installations used grooves cut directly into the motor shaft (around 12mm or so diameter IIRC) & a large diameter plain face "pulley" on the rear of the drum, giving a very large gear reduction.
                                                Polyvee belts in general require a lot of tension to work correctly & wear fast if under tensioned – the amount of wear required on the flanks of the vees isn't much before the belt just ends up driving (more likely slipping) on the points when they hit the bottom of the grooves.
                                                Can't say I am a fan of polyvees though, to be fair, the installations I designed them into were normally "challenging" and where a traditional vee belt solution would not fit the space available.
                                                Nigel B.
                                                #657029
                                                Leo F Byrne 1
                                                  @leofbyrne1
                                                  Thank you for all your help. Pro tem I have bought a Scheppach bandsaw from Screwfix and, after fettling, it it does what I want, viz making brass discs for my friend the golf pro to use in the ball machine. I didn't realise how much I relied on the Kennedy.
                                                  I had a big metal bandsaw years ago but could never get it to do what I wanted and sold it. The Scheppach now cuts square – and quickly! – and the job is now done.
                                                  I will revisit the Kennedy at a later date, probably with v-belts. Having reached a dead halt had prevented me from getting on with other projects of a more important nature – including viola bows.
                                                  What a great site this is!
                                                  Leo
                                                  #657031
                                                  Buffer
                                                    @buffer
                                                    Posted by Graham Meek on 11/08/2023 15:52:23:
                                                    Gray,
                                                    Unwanted graphics
                                                    I could never get the two pulleys parallel on my saw so the belt just kept coming off.   Its been dumped under a bench for years now.
                                                    Edited By Buffer on 18/08/2023 15:29:47
                                                    #657034
                                                    Graham Meek
                                                      @grahammeek88282
                                                      Hi Buffer,
                                                      The common fault with this machine, and it is down to wear in the crank bearings. The crank pulley automatically swivels clockwise due to this wear and in doing so sheds the belt. This wear is due to the high tension required by the original flat belt. With my muscle illness I struggled to get this belt on and off. When the saw is set-up correctly according to the manufacturers data.
                                                      Also I have seen that some saws have motor pulleys with 16 mm bores running on 5/8" shafts. How this ever worked from new I will never know.
                                                      The Poly V has very minimal tension when compared to the original set-up. I had the machine set-up and running in under 5 minutes. With the belt running dead centre on the larger pulley rim.
                                                      Gray,
