Thanks for the reply’s…….when i first got the machine i powered up the head and it spun up no problem, however the head was virtually dry as the oil level sightglass was broken and the oil was thick and filthy
So now iv’e cleaned the machine up a bit, changed the hydraulic oil, replaced the sightglass and put fresh oil/kerosine in the head, removed the table and cleaned out the oil feed holes etc.
Also manouvered it tight against a wall ( A pig to move) and levelled it up with shims.
I tested it yesterday and the spindle motor seemed to be having trouble starting, Lots of humming and sparks coming from the contactor, so i stripped out the contactor, cleaned up the contacts and away it went.
Played about grinding things for approx an hour to get a feel for the controls etc. The head was just warm, not hot. Turned it off and then tried to restart, but no chance. Wired the motor direct and it still wont spin up, it just hums.
The spindle feels tighter than i would have imagined, so am guessing either spindle is tight or motor bearings are shot. Was trying to avoid having to move the machine again, but motor and belt access is from the rear, so looks like i will have to.
Something else im not sure about too. The oil catching resevoir tube in the head had another tin split tube clipped over it, which seems to defeat the object as it would stop oil from getting caught in the trough and looks a bit home made……Any ideas ? See pics
