jet size
jet size
Home › Forums › Beginners questions › jet size
  • #125398
    dave greenham
      @davegreenham19379
      Hi Gentleman
      I'm trying to solder a 4" copper boiler. the boiler is 13 gauge and the end plater is 3 mm. the problem is the solder will not run, yes i know what you are going to say, NOT ENOUGH HEAT. and that silver soldering is easy. I agree it is easy if you can do it. But my question is…. am i better using a big burner on the gun, or would i be better with a smaller size burner ? I'm using Tenacity No5 flux and Brazetec 5507 solder ( 55% ) copper, zinc, tin.. the flux goes clear but the solder just will not run. Yes everything is clean, pickled, washed and wire wool used to shine it up.. Any suggestions please
      regards
      Dave.
      #6798
      dave greenham
        @davegreenham19379
        #125404
          A bigger burner is usually best to bring the whole thing upto heat rater than doing just a smallarea and trying to chase the solder around the joint. I would be looking at a 30-35mm burner on a propane bottle with plenty of suitable bricks to reflect heat back onto the work.
          J
          #125407
          nigel jones 5
            @nigeljones5
            I find T5 flux doesnt flow half as easily as easyflo, but then if your not well versed in SS I gues it is a lot more forgiving. What thickness SS rod are you using, all supposed to melt at same point but the thinner it is the quicker it will melt (from experience)?
            #125408
            dave greenham
              @davegreenham19379
              Hi Fizzy
              the rosa are 1.0 mm also have some 1.5 mm but they take about 3 wks to melt lol
              regards
              dave
              #125409
              dave greenham
                @davegreenham19379
                The rods are 1 mm
                #125425
                Sub Mandrel
                  @submandrel
                  I managed to solder a 3 1/2" boiler with a 17mm propabne burner and a blowtorch for backup. I am confident that anything bigger would need a much bigger burner.
                  Ian S C
                    @iansc
                    I'm not too sure on the specs of your "solder", I'm not a steam man, but shoul it not be a silver based alloy, too late now if you'v used one with tin I think. The experts will be along soon. Ian S C
                    #125453
                      Its a 55% silver one so OK.
                      Same make up as Silver-flow 55 which also has 2% tin (AG155)
                      J
                      Edited By JasonB on 26/07/2013 08:00:31
                      #125461
                      Speedy Builder5
                        @speedybuilder5
                        And Brazetec 5507 even has a little Cadmium in it !! I think I would go with more bricks, and more heat. Copper EATS heat, and is very different than silver soldering steel components.
                        #125463
                        dave greenham
                          @davegreenham19379
                          Hi Gentlemen .
                          thanks for all the advise, I've now cleaned everything up again, but this time I'm going wrap the boiler up in a fire blanket ( meant to have done that the last time but forgot, memory's not what it was lol)
                          I'm pretty sure there was enough heat but the blanket can't do any harm.
                          regards
                          dave
                          #125492
                          Sub Mandrel
                            @submandrel
                            Dave, you don't say how big your torch is?
                            dave greenham
                              @davegreenham19379
                              Hi Neil.
                              all I can tell you is its from Machine mart. Came with 3 burners 12, 14, and 17 mm running on propane at max pressure with largest burner. I don't think it's heat, as when I did the other end of the boiler we even put an Oxy torch on it, Again everything was cleaned with wire wool. And took over an hour to do 4" boiler dia. same thing, It just didn't want to run. That's why I changed the flux to Tenacity No 5 in case I was burning the flux out. Even the tenacity made no difference. The next time I have a go, I'm going to wrap the boiler in a fire blanket. Just to make sure it's not. A heat problem.
                                Did the regulator come with the torch? or are you using a low pressure reg rather than a high pressure one, you want 3 to 4 bar.
                                And the 17 is still a bit small, based on Silvert burners a 17mm gives 1.2Kw, 28mm 7.7Kw and a 32mm 26Kw.
                                Edited By JasonB on 27/07/2013 07:11:12
                                #125523
                                dave greenham
                                  @davegreenham19379
                                  Hi Jason
                                  the regulator came with the torch.
                                  regards
                                  Sub Mandrel
                                    @submandrel
                                    Hi Dave,
                                    The same otorch as mine. The 17mm burner is not enough. Go for the next set up they do and be prepared to use a lotr of gas! Whole set is cheaper than one seivert tip!
                                    Gordon W
                                      @gordonw
                                      Please don't bite my head off, but are you sure you do have silver solder ? Can be easy to mix up. just that I have done it myself.
                                      #125532
                                      dave greenham
                                        @davegreenham19379
                                        Hi Gorden
                                        lol, yes, I'm sure. The only solder I have in rod form is S/solder.
                                        regards
                                        Sub Mandrel
                                          @submandrel
                                          Folks, Dave and I have the FC109 torch kit HERE as Ian suggests I would like to get the FC108 kit sonmetime as although it doesn't seem much bigger the 35mm burner should be about 15 times more powerful and the 50mm must be well scary….
                                          For anyone reading this thread and thinking of getting a torch kit for brazing, THIS would probably be a good a starter kit as any, but oddly it leaves out the 17mm burner, which I suspect is the best for general purpose use, I'd guess at it being about 4-5 times the power of a standard blowtorch.
                                          Edited By Stub Mandrel on 27/07/2013 13:31:55
                                          #125538
                                          dave greenham
                                            @davegreenham19379
                                            50mm ? wonder what the fire brigade charge to be on standby ? Lol
                                            #125540
                                              Also worth making sure you have a decent size propane bottle when using the bigger burners as the bottle will chill quite quickly and pressure will drop. The 3.9kg bottles are a bit on teh small side.
                                              #125542
                                              dave greenham
                                                @davegreenham19379
                                                Hi Jason.
                                                no probs there, it's a 47kg hardly used until I started trying to do this boiler
                                                regards
                                                dave
                                                #126314
                                                nigel jones 5
                                                  @nigeljones5
                                                  You can probably just aboutget away with the torch you have but be prepared for a long wait till it gers hot enough – insulation is a must. I did a 4" copper boiler a while ago with oxy and couldnt beleive how much heat that ate up!! I normally tig but people talked me into doing it the old way (years since I last didnt tig one) and I wont be doing another again for a while! Tig is cheap, strong and looks very nice!
                                                  #126916
                                                  doubletop
                                                    @doubletop
                                                    I'm going to also suggest the 17mm burner is way undersized for 4" tube and 3mm plate. The 50mm Sievert 2944 is 86kW (no the decimal place isn't missing) and the 35mm 2943 is 44Kw that the capacities you need to be looking at
                                                    Celcon/Thermalite blocks for insulation along with the thermal blanket.
                                                    I did see mention of using wire wool to clean the parts, although Tenacity 5 does a good job of cleaning by itself make it easier and pickle the job in a bath of saturated solution of citric acid (baking section in Tescos)
                                                    I'm no expert but one of the been there done that brigade and there’s a similar post from me from only a few years back
                                                    Pete
