Is there an alternative to tufnol strip for springing
Home Forums Beginners questions Is there an alternative to tufnol strip for springing
  • #803503
    steve2250
      @steve2250
      <p style=”text-align: left;”>Been trying unsuccessfully find a source of 1.2mm carp brand tufnol for my 5′ engine and tender rebuild.</p>
      Thanks in advance
      Steve
        Carrbon /Glass/Kevlar Fibre reinforced sheet would seem appropriate … just need to fiddle with the spring-rates.
        Dave Wootton
          @davewootton
          Hi M Machine metals sell 1.2 mm Tufnol sheet, you have to buy it by tha square foot. I found it quite easy to cut into strips with a pair of old fashioned tin snips.
          Doug Hewson has detailed all steel springs in the published articles on his loco designs.
          Perko7
            @perko7
            Have you considered the plastic strapping now used for bundling stuff together instead of steel strapping? Not sure how thick it is in your part of the world but in Australia there is some which is 1mm thick. Maybe make a composite spring of some plastic and some metal leaves?
            #803541
            duncan webster 1
              @duncanwebster1
              Plasticard is available in 1mm and 1.5mm and is a thermosetting plastic. I dont think grp is. You’re not after strength, just cosmetics, the steel does the springing,
              .as michael says you,d need to fiddle with the number of steel/plastic
              #803551
              Dave S
                @daves59043
                1 and 2 mm available here.
                https://www.directplastics.co.uk/tufnol-sheet
                bernard towers
                  @bernardtowers37738
                  If you really need 1.2mm it does machine beautifully
                  #803572
                    Probably worth posting the spec. for reference:
                    https://tufnol.com/fabric-laminates/carp-brand/
                    steve2250
                      @steve2250
                      Thanks for all your input M Machine certainly has a vast stock of material. The drawings call for carp brand but suppliers only seem to have whale brand, will that work, otherwise I’m quoted a full sheet from at Tufnol at £300 so not viable.
                      Yes the drawing adds a steel in the pack for strength as a 5″ 3 cyl Jubilee is Heavy
                      #803612
                      Dave S
                        @daves59043
                        Carp is finer weave than whale in the cotton.
                        In a flat sheet I can’t see that making a difference.
                        You know you can look this stuff up:
                        https://tufnol.com/fabric-laminates/whale-brand-tufnol/
                        #803614
                        Dave Wootton
                          @davewootton
                          Hi Steve
                          M Machine Tufnol not used in anger but combined with steel leaves has shown no sign of sagging too much on the bench. It took a curved set when heated in the same way that the material sold for springs by ME suppliers in the past did. Not sure it contributes much to the springing the steel seems to take most of the strain.
