Not model engineering I know but still relevant I hope.
A friend and his men recently did me a good favour by moving and positioning my new lathe and I would like to repay the favour. In the course of his business he has to remove large bits of machinery from factories and the like. This invariably leaves redundant anchoring studs/bolts sticking out of the concrete floor. Up to now they have gas cut the studs of but increasingly the elfs will not allow the showers of sparks this involves (think food factory/refineries). The same also applies to angle grinding. So an alternative – non spark/flame – method – needs to be found.
Up to now they have been using a length of thick walled tubing and snapping the smaller diameters of but even this often leaves some sticking out of the ground. The larger diameters of course pose even more of a problem. He has asked if I could come up with an idea and make something to do the job. So, given that two (or more) heads are better than one I am looking for suggestions.
The solution needs to be as cheap and cheerful as possible. Any bright ideas?
Rik
