Posted by Robin Graham on 15/09/2018 23:19:47:
Belated thanks for replies – I've always had a bit of blind spot about the VA vs Watts thing, but now I understand. I think. It's a shame that the guy who reviewed the machine didn't give more details about his measuring methods – he obviously went to town on it – so we can't draw any definite conclusions.
I'm still wondering about all all this though. There was a post in another place from someone with a 550W drill press which he felt was under powered for cutting (wooden) plugs. I had a look at the plate on my Fobco Star motor and it's 250W. It'll drill half inch straight into steel, no pilot, without drawing breath. It soars through teak with a 20mm plug cutter.
What variation is there in the efficiency of induction motors I wonder?
Robin.
The power of an electric motor as given on the label is best seen as a hint rather than a fact.
- It's not always clear if the wattage quoted is the input or the output power.
- Power output, efficiency and torque all depend on the load and can't be expressed as a single magic number: you need to see the full specification. And as already discussed, with AC motors there's a hard to understand difference between Volt-Amps and Watts.
- Is the motor rated to deliver power continuously or intermittently? Motors rated for continuous operation are heavy and expensive. As many appliances are only run intermittently it would be daft to fit them with motors rated for continuous operation. There's little harm in overrunning a motor in short bursts provided it doesn't get too hot. But a mistake to fit a 500W motor intended to cool off for 40 minutes after 10 minutes at full power to a machine that's on all day.
Most of the time only designers need to worry about sizing motors and they have access to all the data. Unfortunately a home workshop is a major exception because what's done in them varies so much. The motor may not be matched to the condition of service. If you expect a 500W hobby pillar drill to work as hard as a 500W professional pillar drill, you are cruising for a bruising. Both motors will perform equally well drilling a few holes with sharp drills. But the hobby motor needs time to cool down and if you keep going it will overheat. If a few windings are shorted the motor's power output will be reduced permanently. Also, compared with continuously rated motors, intermittent types are less tolerant of abuse; a heavy handed operator is much more likely to burn-out a hobby machine than a professional equivalent.
When fitting a new motor or, adapting an old one to a machine, it's as important to match conditions of service as it is to match the power rating. This means understanding how heavily the machine will be used in practice. Are you a heavy user or a light one? Worst case, a light user who occasionally binges heavily, which might be the hall-mark of the true model engineer.
Once that's decided some motor plates are helpful, many aren't. When buying a drilling machine it's often possible to tell the difference by looking at the price. A very cheap new machine is going to have limited stamina, and an expensive new machine is likely to be the real McCoy. Unfortunately, there's a whole bunch of stuff in the middle. Buying an ex-industrial machine may be the answer, but bear in mind it may need an expensive new motor.
