In need of a steel ring 132mm dia
Home › Forums › Materials › In need of a steel ring 132mm dia
Viewing 25 posts - 1 through 25 (of 26 total)
  • #29933
    wendy jackson
      @wendyjackson
      Steel ring
      #417677
      wendy jackson
        @wendyjackson
        hi, the time as long gone when I could find most of the material I needed in the scrap skips outside most manufacturing companies. I now find myself needing a 132mm Dia by 15mm steel ring. But how no idea where to look. I know it will need to be rolled out, but it’s far too much for my slip rollers to deal with as the ring needs to take a thread so needs to be 5mm thick or more. The companies my way are not interested or are asking silly money. Anyone have any ideas. Thanks
        #417682
        Alan Waddington 2
          @alanwaddington2
          Rather than rolling some flat it might be easier to cut off a section of tube, somewhere like metalsupermarket might be able to help. Or ask at your local pipe fitting stockist, they usually hold stock up to 6” dia, you might find a straight coupler that fits the bill, 5” schedule 40 is around the size you need, wall will be around 6mm
          #417688
          wendy jackson
            @wendyjackson
            Thanks, but the problem is that I can’t find anyone who sells tube the dia I want with a good wall thickness. And they all have a min length I need to buy if they did.
            #417690
            Hopper
              @hopper
              You might be able to buy a steel pipe flange and turn the OD to 132mm then bore out the middle to size. Lot of swarf though.
              Or pay the money to get a piece of 15mm plate cut in a circle laser cut or waterjetted to rough size.
              Edited By Hopper on 07/07/2019 10:29:44
              Edited By Hopper on 07/07/2019 10:57:33
              #417691
              Chris Evans 6
                @chrisevans6
                I would look at laser or flame cutting a blank. Where are you ? plenty of places here in the Midlands at good prices.
                #417695
                paul rushmer
                  @paulrushmer83015
                  Terry This is a classic case of where are you, my slip rolls will handle 6 by 20 strip. All so a good reason to belong to a club we have several sets of rolls a large scrap box plus many members willing to help. The club is Cambridge.
                  Food for thought Paul
                  #417697
                  FatWelshBoy
                    @fatwelshboy
                    The seller of ebay item no. 264266744373 may be able to help, some of his listings have a mobile number if you want something custom.
                    #417702
                    old mart
                      @oldmart
                      There are several suppliers of discs and rings for sale on ebay, just like F W B's example. If you look at the picture, you will notice that the cut is started inboard of the diameter, which may be a problem. The example shown would probably clean up to your required diameter. The thickness might not be enough if you want 15mm finished. I have bought several rings which saved a lot of machining, you just have to look through the whole lot for the sizes required.
                      #417705
                      Anonymous
                        Posted by paul rushmer on 07/07/2019 10:43:31:
                        The way I read the OP is that the strip would need rolling edge on, so you end up with a ring 132mm OD, ~5mm thick and with a 102mm hole.
                        #417721
                        not done it yet
                          @notdoneityet
                          Posted by Andrew Johnston on 07/07/2019 11:17:56:
                          As in a 5mm washer? I think a piece of 6mm plate, as a starting point, would suffice for that.
                          #417727
                          Anonymous
                            Posted by not done it yet on 07/07/2019 12:16:28:
                            That's the way I read it, and I'd also start with 6mm plate, but I already have some in stock, left over from the traction engine hornplates. A sketch, or confirmation that I haven't gone off at a tangent, from the OP would be good.
                            Edited By Andrew Johnston on 07/07/2019 12:35:18
                            #417728
                            AdrianR
                              @adrianr18614
                              m-machine sell tube 135mm OD x 120mm ID and 5 3/4" OD x 5" ID by the inch.
                              Edited By AdrianR on 07/07/2019 12:39:43
                              #417729
                              wendy jackson
                                @wendyjackson
                                Thanks chaps, sorted now.
                                #417737
                                not done it yet
                                  @notdoneityet
                                  Posted by Andrew Johnston on 07/07/2019 12:34:53:
                                  I think you were on the right lines, Andrew.smiley
                                  #417767
                                  Ian P
                                    @ianp
                                    Posted by not done it yet on 07/07/2019 13:43:35:
                                    I think it would have been nice if the OP (who says its all sorted now) had pressed a few more keys on his keyboard and explained what he wanted in the first place.
                                    Ian P
                                    #417770
                                    Former Member
                                      @formermember19781
                                      #417772
                                      wendy jackson
                                        @wendyjackson
                                        I stated right on my first post what I was looking for, that’s why people could help me instead of making underhand comments.
                                        #417773
                                        ega
                                          @ega
                                          Posted by Ian P on 07/07/2019 17:10:04:
                                          Ian P
                                          and, respectfully, told us how he solved his problem so that others might benefit.
                                          #417776
                                          Former Member
                                            @formermember19781
                                            #417780
                                            Ian P
                                              @ianp
                                              Posted by terry callaghan on 07/07/2019 17:23:01:
                                              I beg to differ. If you had explained you were looking for why were so many of the people that tried to help having to make assumptions and guesses.
                                              My comment, which was only slightly sarcastic and hardly underhand, could have been worded better. It was not your original post I was referring to, but to the fact that when you said it was sorted, did not explain then.
                                              Ian P
                                              #417781
                                              not done it yet
                                                @notdoneityet
                                                I was being a bit of a devil – or perhaps his advocate.
                                                #417828
                                                Hopper
                                                  @hopper
                                                  Posted by terry callaghan on 07/07/2019 12:44:00:
                                                  That's good. How did you sort it? Did you find a piece of pipe the right size in the end?
                                                  #417845
                                                  wendy jackson
                                                    @wendyjackson
                                                    Hi, hopper. I could not find any tube to suit. But did find an off cut of solid steel bar. I will be able to machine to size on my cnc mill. Which will also leave me the unneeded middle for something else at a later date.
                                                    #417875
                                                    Hopper
                                                      @hopper
                                                      Aha, man after my own heart. Well done. Nice when offcuts can be found rather than the expenditure of beer tokens on special orders.
                                                    Home › Forums › Materials › Topics
