Hmmm, fractions you say, when I started my turning apprenticeship in 1960 this was an imperial measurement country, thats because it was our Empire, our Industrial Revolution, used in every country, nay Continent that we colonised. So, all drawings in inches & fractions thereof up to 3 feet then feet & inches, decimals were usually used for accurate dimensions. It was expected that you would convert them in your head or memorise them. Fast forward to the early seventies, some Bright Spark decides we are going Metric, what an obscenely expensive debacle that was,for everyone, imagine converting hundreds of thousands of drawings & machining sketches in the company that I worked for alone. Forward again to the start of my career as a CNC turner, still programs written in Imperial or Metric, ok just put code for one or the other at start of program, terrific I can do that. Finally set, operate & program 2 CNC bar machines with the programs split between the 2 measuring systems.
Now to model engineering, drawings going back over a century, will someone convert to metric ? not unless they have a lifetime to spare. I have on the desk beside me a copy of " Gas Engine construction" published in America in 1900, reprinted by Lindsay Publications, 300 pages, dozens of drawings, immaculate retouched photographs, nowhere can I find a dimension thats not in inches & fractions, if you want to build one better learn to do fractions in your head. Mssrs Ransome, Hoffmann & Pollard used to do a conversion chart, fractional & decimal inches & millimetres in lines across, Lord knows where you would find one these days, my sole surviving example, laminated onto a millboard 3 feet by 2 feet is hanging up in my workshop.
robjon44, unreconstructed Luddite, Charter Member of the Flat Earth Society, NBG & bar
