Nige, spark test is by far the easiest and best way and probably the most reliable for home use, best way to learn is to try some known steels on your grinder. HSS will have a shower of dull nonebussting sparks, check this against a carbon steel and you will see larger shower of bright busting sparks. This will of course not tell you the precise type of steel but gives a good indication. Cheers John
