How to machine Acetal
Home Forums Beginners questions How to machine Acetal
Viewing 2 posts - 26 through 27 (of 27 total)
  • #414613
    Daniel
      @daniel
      Posted by Ian Johnson 1 on 17/06/2019 00:41:14:
      Hi Martin I get those tips from JB Cutting Tools. They usually have a stall or two at classic bike shows (Stafford), steam fairs or model engineering shows. I think you can order on-line too although I haven't tried that yet. I don't know the technical specification for the tips, but if you ask Jenny she will give you the same ones, very good quality. About £3.50 each Silver or Gold I think they are the same spec, gold is prettier though!
      Ian
      I order regularly through their online shop.
      Their website is great to navigate and the whole process very simple.
      ATB,
      Daniel
      AdrianR
        @adrianr18614
        Smart work. laugh
        Presumably it's not just rake you'd need when cutting, but a helluva lotta trailing side clearance to avoid rubbing on the helix angle.
        I meant to ask: would have been easier to find a way to re-use the business end of the existing stirrer by joining to a new stem in some way?
        I must admit I did not worry about clearance, The tool was quite small and had a good front clearance so it did not interfere much.
        I did think about fixing the old one but;
        • The plastic feels like the type that doesn't glue well.
        • I thought of splinting with a stud down the middle, and in fact the motor spindle end is threaded, but the motor runs backwards and it would unscrew.
        • I thought of making a socketed sleeve, but I am not sure how good the alignment between the motor and the oil tube is, so It could end up stressing the shaft.
        • The mill is 19 years old, and the plastic could be brittle.
        • There is no way to know if the oil pump is working.
        So I decided making a new one is probably the safest. The Acetal does seem to be slightly more flexible than the old one, and I have strengthened the point that broke.
        Adrian
