In the photograph above.
In the hold down slot which is supporting the Sector Arms is the head of a slotted grubscrew. This grubscrew limits the rotation of the eccentric. This is used to adjust the depth of engagement of the worm. Once set, it will last for years. It also allows the worm to be swung out of the way when the table is used for direct indexing.
It also retains the eccentric bush endwise. If you can pull the worm assembly out when the M6 capscrew is released then the grubscrew is not there.
Gray,
