HMS Queen Elizabeth: Leak found on new aircraft carrier
Home › Forums › The Tea Room › HMS Queen Elizabeth: Leak found on new aircraft carrier
Viewing 25 posts - 1 through 25 (of 143 total)
  • #332684
    Jon Gibbs
      @jongibbs59756
      I read this and thought it must be a huge leak.
      …but then it boils down to it we're talking a litre of water every 15-20 seconds through a prop shaft seal.
      If that's the worst they can find then the new HMS QE must be bloomin' great!
      Jon
      #35070
      Jon Gibbs
        @jongibbs59756
        #332686
        Brian Wood
          @brianwood45127
          I would have thought that was what you might expect on shafts and seals of that size and most certainly within the capacity of bilge pumps to shift it without even noticing.
          Do we have another example of media hype and hysteria here?
          #332687
          Ady1
            @ady1
            The UK's new aircraft carrier, HMS Queen Elizabeth, is leaking because of a faulty seal.
            The Royal Navy's future flagship, which was commissioned by the Queen earlier this month in Portsmouth, has a problem with one of its propeller shafts.
            The fault on the £3.1bn carrier was first identified during sea trials.
            A Royal Navy spokesman said the ship is scheduled for repair and the fault does not prevent it from sailing again early in the new year.
            According to the Sun newspaper, HMS Queen Elizabeth has been taking on up to 200 litres of sea water every hour because of the fault.
            Brian H
              @brianh50089
              Maybe they'll manage to fix it by the time we have some aircraft for it.
              #332693
              V8Eng
                @v8eng
                I thought Sea Trials were partly to make sure everything worked and find any unexpected problems?
                Edited for spelling.
                Edited By V8Eng on 19/12/2017 09:33:27
                #332694
                Bob n About
                  @bobnabout
                  Can't they drill a hole to let the water out !!!
                  #332695
                  Brian Wood
                    @brianwood45127
                    My old boss at Rolls-Royce used to say " Never believe what you are told, and only half what you see"
                    A rather jaundiced view of things perhaps, but if the Sun reports a leak of that size through a prop shaft seal, who are we to argue with the might of our well informed press? Who indeed!!
                    See my earlier post. If true, the leak is still only 40 gallons an hour, about as much as a fast dripping tap. The press needs to get a sense of perspective.
                    #332696
                    Jon Gibbs
                      @jongibbs59756
                      At 70,600 tonnes she'd take 40 years to sink at that rate if they left it
                      Edited By Jon Gibbs on 19/12/2017 09:31:22
                      #332697
                      V8Eng
                        @v8eng
                        Unfortunately trial by media in many things seems to be all too prevalent lately.
                        #332699
                        Tony Pratt 1
                          @tonypratt1
                          The media never let the truth get in the way of a good story.sad
                          Tony
                          #332700
                          Jon Gibbs
                            @jongibbs59756
                            To be fair, it's not just the Sun, it's being almost universally reported today.
                            #332703
                            V8Eng
                              @v8eng
                              I first saw the story on BBC Breakfast at about 6.30 this morning.
                              Edited By V8Eng on 19/12/2017 09:48:45
                              #332705
                              Martin Kyte
                                @martinkyte99762
                                Engineering wise, I would not be worried about the leak but rather about the cause for the leak. Something isn't right because it's not functioning as it should.
                                regards Martin
                                #332706
                                  @mike89748
                                  The press had a field day with this story this morning. By picking on a tiny fault they are holding the Royal Navy and Britain up to international ridicule. Have they no pride in their own nation? As a (mostly retired) journalist I am disgusted by the antics of the media these days. Shame on them!
                                  #332707
                                  Ady1
                                    @ady1
                                    An old Navy guy would just give it a few taps with a Coventry spanner on the night watch
                                    The modern navy guys will probbly spend a couple of million sorting it out
                                    Edited By Ady1 on 19/12/2017 10:07:46
                                    #332709
                                    not done it yet
                                      @notdoneityet
                                      Question to ask is how much water might be taken in if the (faulty) seal actually failed completely. A dripping tap of the historical brass seat type would soon drip much faster due to the brass being cut away by the initial tiny water jet under pressure.
                                      But, yes, it is a relatively trivial problem to get sorted, I would think. Probably need extra greasy packing, or for the gland nut to be tightened half a turn!
                                      #332710
                                      Circlip
                                        @circlip
                                        All gone to pot (?) since the advent of inside toilets and soft toilet paper.sarcastic
                                        Regards Ian.
                                        #332715
                                        David Colwill
                                          @davidcolwill19261
                                          Posted by Circlip on 19/12/2017 10:12:04:
                                          Regards Ian.
                                          Outside toilets on ships are not such a good idea smile p
                                          #332716
                                          Brian H
                                            @brianh50089
                                            Ships in Nelsons time had outside toilets, they were called heads.
                                            #332717
                                            Ady1
                                              @ady1
                                              Fortunately for the Navy no one in the media has noticed that their aircraft carrier has no aircraft yet
                                              #332718
                                                Samsaranda
                                                  @samsaranda
                                                  So it's not quite life jackets all round yet?
                                                  Dave W
                                                  #332724
                                                    @mike89748
                                                    Interesting that damage was first examined at Invergordon, at the head of the Moray Firth. Wonder if she picked up a broken length of wire-cored trawl warp? I live by the Firth, and bits of fishing industry debris are washed up almost daily.
                                                    #332725
                                                    Bob Rodgerson
                                                      @bobrodgerson97362
                                                      I remember a similar experience from my shipbuilding/marine engineering days 19 the early 1970's during sea trials of the ferry St George. She was experiencing severe vibration, especially when in reverse. It was so bad at the aft end of the ship that in some cabins you couldn't stand comfortably, let alone sleep. I seem to recall that we had a job keeping up with water ingress into the shaft tunnel and the bilge pump was running constantly to keep up with it. It was believed that the welds on one of the hull plates had cracked due to the vibration.
                                                      The ship was dry docked immediately on return from her trial and a 25 gallon paint tin was found to be caught either around the shaft or between the variable pitch blade and the prop boss. The plate was welded up and on removal the severe vibration was no longer present.
