Thanks for the info Jack. The burner shown in the video is stable in air and also when used in the forge he also shows but doesn't give any details on.
I'm hoping that the ceramic blanket material saves on the refractory needed. i'd guess that the volume of a bag of it is roughly equivalent to how much material can be cast. Some people seem to be using blanket for forges and nothing else so it should give pretty good heat insulation.
I have a couple of crucibles that were given to me some time ago which are probably a bit full with 2 lt in them but should be ok for 1 1/2. Not sure what to do size wise yet but I'm thinking in terms of going for kiln style with a front opening door probably with a plug in the top for adding more material. Not what most do but to me that gives a bit more flexibility size wise than looking for suitable barrels. So probably size it on a bigger crucible than I have.
Materials can be found here but I bought my bag off ebay.
Checking my ebay purchases I actually have the 1700C material but didn't pay that much for it. I also have a few insulating fire bricks that have been around for some time. They should be ok to make a base for it if I coat them with the high temperature stuff.
While electric makes temperature control easier it wont be easy to judge the wattage needed. I can get a rough idea by looking at various kilns especially glass furnaces at the sort of size I am likely to finish up with. Rather than go for one element I've gone for several of the same wattage so hopefully I can sort of tune it. eg 5 1kw elements worked out at £9 from a UK seller. 3 800w from the east £5. Should leave some spares. I'm almost bound to burn some out but a type of dimmer switch might prevent that happening while I'm messing about. The initial low resistance might blow these up but I can probably sort that out with a heftier triac.
