Harrison L5a lathe
Harrison L5a lathe
Home Forums Manual machine tools Harrison L5a lathe
  • #220521
    roger kerry
      @rogerkerry44257
      HI all,
      I want to strip my norton gearbox thats fitted to a Harrison L5a lathe. I have the gearbox off the lathe & partially stripped, but am unable to work out how to remove 2 of the shafts & corresponding gears.
      Can anyone help with advise or know where i can find info in a manual or publication??
      Any help greatly received..!!
      Many thanks
      Roger
      roger kerry
        @rogerkerry44257
        Norton gearbox
        #220626
        Kettrinboy
          @kettrinboy
          p1010275.jpgHi Roger
          a fellow L5 owner here , i have taken a couple of photos out of my owners manual of the norton gearbox assy and spare parts list , hope you can make out the detail , i think some taper pins may be involved in retaining things but i havnt had to go this deep into my lathes workings yet so dont know for sure, my lathe is 1963 vintage so this handbook will be for machines of that era presumably.
          Edited By Kettrinboy on 11/01/2016 20:11:16
          #220649
          roger kerry
            @rogerkerry44257
            Many thanks for your help Geoff.
            unfortunately i have these already.
            Anyone else out there with any more info greatly appreciated
            Thanks Roger
            #220655
            Kettrinboy
              @kettrinboy
              Ah ok , you could try harrisonlathe@yahoogroups.com perhaps someone on there could help
              #220758
              roger kerry
                @rogerkerry44257
                Hi kettrinboy
                Thanks for the link. I have emailed the question & awaiting an answer.
                #220839
                roger kerry
                  @rogerkerry44257
                  Can anybody point me in the right direction for spare parts for the Harrison L5a lathe particularly bronze bushes for the Norton gearbox.
                  #220909
                  Chris Evans 6
                    @chrisevans6
                    I will stick my neck out and assume the bronze bushes will be standard bought in items ? If so available from a bearing supplier, I tend to use Simply Bearings. Other suppliers are available.
                    #220962
                    roger kerry
                      @rogerkerry44257
                      many thanks chris, will look into it.
                      #221964
                      roger kerry
                        @rogerkerry44257
                        you were right Chris, the bronze bushes were standard imperial sizes & easy to obtain. But will require drilling for the oil ways
                        The `reverse shaft`(L5-2-179) & `The bearing`(L5-2-116) are both badly worn & require replacing.
                        Can anybody point me in the direction of a spares supplier…??
                        Many Thanks.
                        #221965
                        mechman48
                          @mechman48
                          Try …
                          Chris Evans 6
                            @chrisevans6
                            Can the reverse shaft be ground to clean up and a bush turned to suit ? Most case hardened shafts have around thirty thou of "case" If you think it is soft after grinding get it tuftrided ?
