I own one of these, and bought the photocopied version of the Operator's Manual from lathes.co
Apart from anything else it will mean you are less likely to be caught out by that small gearbox on the headstock. (Yes, I have been…)
Norton Gearbox or not, and mine doesn't have one, you will still need a 127T wheel for cutting metric threads, but you may also have to reverse the lathe to wind the saddle back still in gear for each pass. I am not sure if you can use the lead-screw reverse gear to avoid running the spindle backwards – I think that would lose the correct meshing.
BEWARE though if you do run the lathe backwards under power and it has the same screwed spindle as on my lathe, you do risk the chuck unscrewing itself from the nose.
You might get away with a 63T wheel instead of 127, but it introduces a small pitch error and is best used only over short threads.
