Does anyone have one of these, or it's East German predecessor ?
I have a Groz version, purchased on offer (from Axminster Power Tools, I think) many years ago & notice that it is still available from Chronos and others. I have played around with it on thin sheet steel & recently made a couple of "U" bolts from M6 stainless studding, but otherwise it has seen little use.
I had a requirement to make a couple of dozen brackets at work from 40mm x 3mm galvanised perforated strips and, rather than beat them into submission, took the metal bender in today. According to the description of the capacity of the tool it should have been able to produce right-angle bends in 40×3 strip, though this is right on the stated upper limit.
First problem was that 40mm strip (actually 39.5) would not enter the body of the bender – a rough casting complete with mould release taper that measured nearer 38.5mm than 40 at the larger end. So the strips were milled en-mass to 38 wide. The tool was assembled & held in a vice – the first strip bent to around 45 degrees (I was aiming for a right angle), then the rack section of the tool that applies pressure to the job bent. I ended up pounding the brackets to shape after all.
The bent rack section bent back straight rather more easily than I was expecting & I wondered if the original East German versions had hardened parts. I had originally assumed that "Groz" was an East European maker, but it is apparently Indian according to the instruction sheet. My experiences with Indian tools have been less than favourable & this one appears also to look like a reasonable tool but fails to operate as expected due to poor manufacturing and/or materials specification.
It may be that I was just pushing it's envelope a bit too far (the galvanised strip may well be tougher than plain sheet steel sheared from plate), but I would be interested hear of other's experiences with this device – particularly if anyone could confirm (or deny) that the East German original used hardened parts in it's construction.
Nigel B.
