GripTru Chuck Pin stuck!
Home › Forums › Help and Assistance! (Offered or Wanted) › GripTru Chuck Pin stuck!
  • #287757
    Martin King 2
      @martinking2
      Hi All,
      Got 3 Griptru chucks and just started to dismantle the first smallest one which is basically quite good but one or two dings and filthy inside.
      All went OK until I tried to remove the last of the 3 chuck key gears. The small retaining pin has sheared off at the screwdriver slot, (not me, already done!) and despite gentle heat, WD40 and tapping etc will not budge! Cannot remove the scroll for cleaning until this is out.
      Any thoughts please?
      Cheers, Martin
      #32917
      Martin King 2
        @martinking2
        #287859
        vintagengineer
          @vintagengineer
          Drill it out with a lefthand drill.
          #287866
          daveb
            @daveb17630
            That sounds like an EDM job! Cheaper than messing up the chuck.
            #287870
            Martin King 2
              @martinking2
              EDM?
              Martin
              #287873
              David Standing 1
                @davidstanding1
                Electrical Discharge Machining – spark erosion wink
                #287985
                Martin King 2
                  @martinking2
                  All sorted! I carefully centred the hole with the pin using a conical centre in the top of the hole then heart in mouth plunged a 2.5mm solid carbide slot mill gently down and down. Finally the remaining little stub started spinning and out it came! Made a new pin and job done.
                  Cheers,
                  Martin
