Grease in oil lines
Grease in oil lines
Home Forums Workshop Tools and Tooling Grease in oil lines
  • #598515
    Alan Waddington 2
      @alanwaddington2
      Picked up a new to me mill at the weekend, seller proudly mentioned he had greased all the nipples to save me the trouble……yep he’s greased all the oil nipples to the ways. So whats the best thing to do, thought about pumping some diesel through to flush the grease out, followed by the correct way oil……..thoughts on a postcard ?
      #20699
      Alan Waddington 2
        @alanwaddington2
        #598517
        Steviegtr
          @steviegtr
          I go for Paraffin Alan. Or Turps.
          Steve.
          #598518
          noel shelley
            @noelshelley55608
            I think I would just give it a good dose of SAE 10 hydraulic oil. Noel
            #598523
            Hopper
              @hopper
              +1 on what 'e said. Oil will dissolve the grease. Might make the oil a bit thicker than normal (matching the previous owner!) but flush a bit through and it should be ok.
              #598526
              David George 1
                @davidgeorge1
                Hi what mill is it as some mill's use grease on some parts like a Bridgport uses a white grease for varidrive bitts.
                David
                #598527
                Ady1
                  @ady1
                  Pump air through from an empty grease gun
                  light oil to dilute residual grease
                  Low pressure compressed air to blow the tubes through
                  It's annoying but only an inconvenience
                  Edited By Ady1 on 18/05/2022 08:49:49
                  #598533
                  Swarf, Mostly!
                    @swarfmostly
                    Good morning, Alan,
                    How long had the seller owned the mill?
                    Was this the first time he had attended to its lubrication? Had he been using the mill with dry ways?
                    Or had he regularly lubricated the machine with grease?
                    Which is worse?!?!
                    Best regards,
                    Swarf, Mostly!
                    #598534
                    Greg Bowl
                      @gregbowl10135
                      Would you pump the oil through from a gun to try and force it out or leave it to dissolve and do its work slowly?
                      #598536
                      Dave Halford
                        @davehalford22513
                        Posted by David George 1 on 18/05/2022 08:40:50:
                        David
                        As do the Centec vertical heads.
                        That said, any oil galleries on older machines have a habit of blocking anyway. I found gunge in the internal gearbox oilways of the Centec and you can't get grease into those by mistake.
                        Edited By Dave Halford on 18/05/2022 10:23:40
                        #598542
                        Alan Waddington 2
                          @alanwaddington2
                          David
                          It’s an Aciera F4 David, fortunately it came with a manual, including a lubrication schedule, which previous owner obviously didn’t bother reading !
                          And to answer Swarf Mostly’s question. Fortunately the ways seem to be in A1 condition, so no harm done either way.
                          #598781
                          old mart
                            @oldmart
                            We had that with the museum's lathe, some parts were dismantled and washed, but others were simply force lubricated with oil. Mike modified all of the common nipples by removing the springs and balls and produced a 90 degree internal chamfer so that an ordinary oil gun tip can fit well enough to not leak much when the oil is pumped in. There are about 7 nipples around the headstock and they now have plastic caps to keep them clean. The trouble is that the nipples are the same as grease ones and can fool some people.
                            Edited By old mart on 20/05/2022 21:18:33
