Gibraltar Toolpost
Gibraltar Toolpost
Home Forums General Questions Gibraltar Toolpost
Viewing 23 posts - 1 through 23 (of 23 total)
  • #26717
    Lynne
      @lynne
      Lynne
        @lynne
        Sometime ago an article appeared in issue ? could anyone give me
        the issue number. Lynne
        #419159
        Peter G. Shaw
          @peterg-shaw75338
          My homemade database gives MEW139, page 31, dated Jun 2008.
          My notes say:
          The author came actoss Tubal Cain's Gibralter toolpost and decided to make his own from mild steel (instead of cast iron or buying) and included a modification for quick change tool holders.
          Is this the one you want?
          Peter G. Shaw
          #419175
          Mike Poole
            @mikepoole82104
            Hemingway do a kit for a Gibralter toolpost, could make life easy.
            #419227
              This is actually for a vertical slide, but I made a very similar block, fitted with an M10 stud, for my Mini Lathe as an alternative to the top slide for 'Gibraltar' performance with the standard tool holder.
              #419249
              Alan Johnson 7
                @alanjohnson7
                Construction of a Hemmingway kit was published in Model Engineer No. 3618, Volume 145, in 1979.
                #419410
                Lynne
                  @lynne
                  Thanks for all the responses. Have read the article in 139, useful detail. Will also have a look at the Hemmingway toolpost. Do not often read M.E so it was'nt there that I saw the article. Regards Lynne
                  #419413
                    Lynne
                    I've just found this rather nice variation on the theme, which might inspire: **LINK**
                    Roderick Jenkins
                      @roderickjenkins93242
                      The Gibralter Toolpost is also detailed in Tubal Cain's book "Simple Workshop Devices"
                      Rod
                      #419564
                      Lynne
                        @lynne
                        Michael, thanks for the link. interesting, but not quite what I had in mind for the '7'. I like the Aloris toolpost.
                        I hate Imojis, and I do not visit sites where I know they are mobile>
                        Rod, thanks for the reference to tubal caine's book. Lynne
                        #419716
                        Mark Rand
                          @markrand96270
                          The residents of the rock, And the late Tom Walshaw might prefer it if folks referred to the Gibraltar tool post by its correct name. cheeky
                          Edited By Mark Rand on 18/07/2019 22:28:36
                          #419717
                          Mike Poole
                            @mikepoole82104
                            Oops tripped up there.
                            Edited By Mike Poole on 18/07/2019 23:06:41
                            #419724
                            Roderick Jenkins
                              Posted by Mark Rand on 18/07/2019 22:28:24:
                              blush
                              #419738
                                … and, just to work this to death [sorry, Lynne]
                                When I first saw the thread title, I thought "surely there's a double g in Gibber"
                                https://www.everywhereist.com/the-monkeys-of-gibraltar/
                                Edited By Michael Gilligan on 19/07/2019 06:44:29
                                #420101
                                ChrisB
                                  @chrisb35596
                                  I have a question related to the subject in this thread so I'll ask here rather than starting a new thread. (If not appropriate let me know and I'll open a new thread)
                                  I would like to replace my compound slide with a solid tool post on my WM280. I've seen lots of videos and plans on youtube – every one I saw use cast iron for the base. I would not know where to get hold of a piece of cast iron from my location, so I was wondering if black mild steel would do instead?
                                  #420102
                                  Ian S C
                                    @iansc
                                    ChrisB, I don't see any problem.
                                    Ian S C
                                    #420104
                                    Tony Pratt 1
                                      @tonypratt1
                                      I used cast iron but mild steel will be no problem.
                                      Tony
                                      #420139
                                      ChrisB
                                        @chrisb35596
                                        Great, thanks. I'll get a chunk of steel next week.
                                        #420143
                                        ega
                                          @ega
                                          Posted by ChrisB on 21/07/2019 09:52:31:
                                          … I would not know where to get hold of a piece of cast iron from my location …
                                          Malta has not always been an ME desert; David Urwick of Metal Master fame lived there some years ago.
                                          #420153
                                          ChrisB
                                            @chrisb35596
                                            Hi ega, unfortunately I'm not much aware of the local ME status on the island, however you got me curious and after a quick check it seems ME is still alive and kicking. From what I've seen of their FB page it's more inclined to scale models of ships and aircraft, but there are also some steam engines as well. **LINK**
                                            As for cast iron, I believe there are a couple of foundries on the island, but as far as I know they do commissioned work such as lamp posts, bollards and other street furniture. So not sure they'll sell raw material as such.
                                            #420159
                                            ega
                                              @ega
                                              ChrisB:
                                              Thanks for the link. You seem to have an impressive number of MEs per head of population!
                                              #420397
                                              Nick Hulme
                                                @nickhulme30114
                                                I have a Long Bed Super 7 and can take deep, accurate cuts on 30mm OD 304 stainless steel without need for a special tool post.
                                                This leads me to think that the short bed Myford 7 lathes have a level of bed flexibility that require solutions not required for the Long Bed.
                                                #420423
                                                Mark Rand
                                                  @markrand96270
                                                  The long bed Myford ML7's do have a much heavier bed casting than the short bed ones. They also use the Super 7 style cross slide and top slide, which are an improvement on the earlier ones.
