Form Tool or other way?
Home Forums Beginners questions Form Tool or other way?
Viewing 25 posts - 1 through 25 (of 38 total)
  • #239340
    James Jenkins 1
      @jamesjenkins1
      Hi all,
      I am going to be making a 2" round belt pulley for one of our textile machines (and easy early project I thought!). Here is the drawing for it:
      Am I right in thinking that the best way of turning the internal radius, where the belt sits, is with a series of stepped cuts to remove the bulk of the waste, followed by a form tool created to the correct radius? If so, what is the best method for creating the form tool? Ground Flat Stock, shaped and hardened? Or HSS ground?
      If Ground Flat Stock, will 10mm thickness be sufficient? If HSS, do I have to re-harden it afterwards?
      Many thanks in advance for your help!
      Kind regards,
      James
      Edited By James Jenkins 1 on 19/05/2016 16:27:42
      Edited By James Jenkins 1 on 19/05/2016 16:31:00
      Edited By James Jenkins 1 on 19/05/2016 16:31:26
      James Jenkins 1
        @jamesjenkins1
        #239345
        John Reese
          @johnreese12848
          If this is a recurring job, I suggest having a custom tool ground on a HSS blank. If this is a one-off job, make a button from hardenable rod and screw it to a steel shank. Ivan Law's book on gearing shows how button cutters are made.
          #239346
          Emgee
            @emgee
            Hi James
            You seem to have an error on the drg, at the top you show 0,375" diameter but at the btm you quote 0,203" radius, does this mean a 3/8" belt running in a wider groove ?
            Not that it makes much difference to the tool, if you can grind a HSS blank to the required radiused end with good clearance angles you could use it as ground, it wouldn't need further hardening. Even after roughing out some material it is quite a long cutting edge so I believe you would need to turn at low rpm with lubricant to avoid chatter marks.
            Emgee
            #239348
            Tony Pratt 1
              @tonypratt1
              Easiest is FGS, shape when soft, harden & temper, or button tool from Silver steel. 10mm thick is plenty.
              Tony
              #239349
              duncan webster 1
                @duncanwebster1
                You can get carbide button tools, certainly as big as 8mm and I wouldn't be surprised if you could get 10mm. 10mm is 0.394 which is close to your 0.203 dimension. If this is too expensive then as John Reese says, make one out of silver steel, or if you're really strapped for cash grind down an old square file to the required end radius. With carbon steel go slow or you'll overheat and kill the hardness
                #239351
                Michael Cox 1
                  @michaelcox1
                  I have never tried this but I would make a holder that could press a 3/8" endmill against the edge of the pulley and allow the side flutes to shave the metal off.
                  #239362
                  I.M. OUTAHERE
                    @i-m-outahere
                    3/8 sq tool steel with a hand ground radius
                    Clamp the tool steel in a vise with the top surface just below the top of the vise jaws use a 3/8 drill shank end as a guide and a carbide scriber to mark out the radius then grind on a bench grinder and finish on an oil stone .
                    Set your grinder rest up on centre height of the grinding wheel this will give you enough relief angle under the cutting edge
                    Your biggest enemy will be chatter , i would stop just shy of the required depth and shut the lathe off then use hand power to rotate the chuck and feed in the tool a few thousndths every second rotatoin of the chuck this will clean up the chatter .
                    Then give it a polish with some fine emery , the most important thing is that the bore and the surface where the belt runs are true with each other and the surface the belt runs on is smoothe and remember it is a pulley not a precision gear so you have a little bit of room to play with
                    #239367
                    Bazyle
                      @bazyle
                      Steps as you said and round file?
                      #239369
                      Michael Cox 1
                        @michaelcox1
                        Posted by Michael Cox 1 on 19/05/2016 17:37:18:
                        Forget this idea. It will only work if the end mill can be rotated at the same time as it is pressed against the rotating pulley.
                        #239374
                        John Stevenson 1
                          @johnstevenson1
                          Weld a 3/8" ball bearing to a stick of metal for the tool, then grind half away, instant, simple form tool already hardened.
                          #239376
                          Bernard Wright
                            @bernardwright25932
                            JB Cutting Tools have this **LINK**
                            Bernard
                            #239383
                            Muzzer
                              @muzzer
                              It's going to be one hell of a width of cut if you use a semicircular tool, something like 15mm along the circumference towards the end. Don't imagine it will be easy to avoid grievous judder unless you have a beast of a machine.
                              I made some mandrels in steel for my pipe bender – looked similar before I cut the wheel into 3 sectors although somewhat bigger. I turned the bulk by eye with carbide tooling and although it was pretty good, it wasn't perfectly circular by the time I declared I was finished.
                              If you have one of those radius tools for turning balls etc, they give a very precise finish particularly if you use a (round) profile cutting insert, judging by photographic evidence. I thought about using a milling cutter (3/8" in this case) but don't think it would have been easy going.
                              #239390
                              Rainbows
                                @rainbows
                                You might want to consider using a V profile on the pulley. My Wizard lathe is designed for round belt but used a V shaped pulley. Best way to cut a V is do a parting cut down the centre then a cut on each side to establish the angled face.
                                #239391
                                James Jenkins 1
                                  @jamesjenkins1
                                  Thank you so much everyone for your input, really, really helpful. I certainly don't have a 'beast of a machine', just a treadle powered Drummond M! The measurements came from a commercial pulley design and they seem to make the internal radius just over that of the band, so who am I to argue?
                                  Whilst spending £20 on a tool with JB Cutting, that I might just never use again, seems rather extravagant to make a simple alloy pulley, it does mean I have one less thing to learn/worry about (tool making) in these very, very early days of learning to use the lathe. I am sure in a years time I will look back a laugh at money wasted and the fact that I didn't just make one. But I tend to find that if you don't make learning new skills as incremental as possible you quickly get overwhelmed! Maybe that's just me.
                                  I saved a few pennies by buying an off cut of aluminium on eBay, which will help pay for it and hopefully this tool will also give me the best chance of succeeding as well (which is also a key part of learning I tend to find!)
                                  I'll let you know how I get on.
                                  James
                                  #239401
                                    What is the pulley material? If you can, choose something easily machinable.
                                    I agree a silver steel button on a steel shank is the easiest way, with the top ground to give some top relief.
                                    Roughing the groove will help reduce the work to be done and avoid over-heating the tool.
                                    I made a 3/8" concave form tool in 1/8" gauge plate and that was ample for brass.
                                    If chattering is a problem, grind two tools that are a quarter circle on the end – one for each side of the groove, it won't be hard to align the second cut with the first.
                                    Tony Pratt 1
                                      @tonypratt1
                                      Neil,
                                      Drawing says Aluminium.
                                      Tony
                                      #239404
                                      Roderick Jenkins
                                        @roderickjenkins93242
                                        Posted by James Jenkins 1 on 19/05/2016 20:31:24:
                                        Obviously I don't know the application, but for round belts it is usual to make Idler pulleys with a groove radius slightly larger than the belt but to use a V section for Drive pulleys.
                                        HTH,
                                        Rod
                                        #239408
                                        John Haine
                                          @johnhaine32865
                                          Treadle lathe, 3/8 dia TC button tool? That sounds like hard work!
                                          Personally I'd use a small button tool and CNC it, but not on a treadle lathe…
                                          #239412
                                          duncan webster 1
                                            @duncanwebster1
                                            Now that's really got me going, CNC conversion on a treadle lathe, come on someone must be up for a challenge
                                            #239413
                                            John Reese
                                              @johnreese12848
                                              Since you are using a treadle machine you certainly do not want wide tool contact. Why not grind up a graver with a radius and finish the groove free hand? Unless the belt running in the groove is under extreme tension the groove need not be the exact radius.
                                              #239417
                                              James Jenkins 1
                                                @jamesjenkins1
                                                Hi Everyone,
                                                Thank you, some more really helpful comments. The machine is this one: **LINK** (Click to play the video). I am replacing the existing old 1425rpm 1/4hp 240v motor, with a 2800rpm, 36v, 250w motor as we are working to make all the electric machines in the studio solar powered (except the weaving looms which are treadle powered!).
                                                To be honest the existing drive pulley is a V profile, but I assumed that this was used simply because that is what the crofter had to hand (the machine is from the Isle of Lewis on northern west coast of Scotland where everything is bit Heath Robinson!). But perhaps not… certainly the driven pulley, which is 7", is also V profile. Perhaps this is my answer?
                                                James
                                                Edited By James Jenkins 1 on 19/05/2016 22:46:51
                                                Edited By James Jenkins 1 on 19/05/2016 22:47:34
                                                Edited By James Jenkins 1 on 19/05/2016 22:47:52
                                                #239420
                                                  Posted by Roderick Jenkins on 19/05/2016 21:13:08:
                                                  HTH,
                                                  Rod
                                                  James,
                                                  I agree 100% with Rod's comment
                                                  … and I think you have a wonderful project there
                                                  Best wishes for its success !!
                                                  John McNamara
                                                    @johnmcnamara74883
                                                    Old pre second world war Singer sewing machine heads had v drive pulleys, they were usually driven by round leather belting, this allowed the metal staple used to join them to pass through the V if set correctly. The round belt would slowly form into a rounded top and bottom V. If you can find it the best belting has a little hair on the top surface. It was left there to prove that the belt was cut from the top layer of the hide. A good belt would last for years of daily industrial use.
                                                    James Jenkins 1
                                                      @jamesjenkins1
                                                      Thanks everyone, it seems a V profile is the the way to go and will be easier to turn as well. A double win!
                                                      I'll revise the drawing and post a pic of the finished item when done.
                                                      Thanks again everyone, really, really appreciate it.
                                                      James
