Hi
I have the Australian branded equivalent of the Warco 3024MW/3003MW mill drill. It is an excellent machine and I have no real
gripes with it except for the lubrication system.
It has those dicky little brass inserts with a spring loaded ball bearing against which you are supposed to press a high pressure
plunger/pump.
ON these machines there is only one of the little buggers per side and it is in the middle of the table. To get to it you have to
wind the table almost to its extent, remove the way protector and then hold said plunger at exactly ninety degrees and press. It does not work. The oil gallery has a capacity of less than two millilitres and because the table is wound so far out, any oil that does make it into the hole is liable to end up directly on the floor.
Thus far I have taken to winding the table to full extent in both directions with the gib loosened off as far as possible, rubbing
oil on the ways by hand, then lifting the table from the rear as I wind it back in. This allows more oil to be
carried in but it is a pain.
I have read the articles on adding forced lube to both the Myford and an X3(2?) with interest and a pair of glasses. I have
thought about a similar system myself but am at a slight loss as to how to approach the rear slide.
Does anyone have any ideas please?
Thanks, Lawrie
