Flux for soft-soldering stainless steel
Home › Forums › Beginners questions › Flux for soft-soldering stainless steel
  • #546387
    Hillclimber
      @hillclimber
      Can anyone recommend an easily accessible (ie no chemistry set required) flux that will allow me to soft-solder stainless steel?
      Before you ask, I have to shorten some multi-strand stainless steel control cables of about 1.6mm overall diameter. I normally 'flash' these cables with a TIG welder, which prevents them turning into feather dusters at the end. But I am working today with some very flexible cables with particularly fine strands, which leave me with odd strands peeling out. Hence, prefer to solder these and then cut.
      Cheers, Colin
      #10846
      Hillclimber
        @hillclimber
        #546390
          Delivery costs are a bit of a killer but this does the job
          #546404
          MichaelR
            @michaelr
            Phosphoric Acid based flux Here
            #546419
            Speedy Builder5
              @speedybuilder5
              Many off the shelf "rust killers" are phosphoric acid based and will work
              #546455
              Keith Hale
                @keithhale68713
                Hi Colin
                Jason is on the right track.
                You can avoid the "killer delivery costs" by buying their stainless steel soft solder 2207 with a suitable flux core. Buy as much or as little as you need. The product can be sent through the post. Normal postal charges apply.
                You also get an excellent colour match to the steel.
                Why is it called 2207? One of my daughters was born 22nd July 😄
                Keith
                #546519
                Hillclimber
                  @hillclimber
                  Chaps, thank you all for that help.
                  Keith's combination of ideas wins out for this small job. But I realise that it's 'an inside job'….!
                  Cheers, Colin
                  #546649
                  Keith Hale
                    @keithhale68713
                    Hi "Hillclimber"
                    " Inside job?"
                    Please elaborate.
                    Delighted (?) that you were able to find the answer to your situation.
                    Keith
                    #546804
                    Hillclimber
                      @hillclimber
                      Keith, I was scratching around other soldering posts after placing my initial query here. And realised how much you contribute to the sum of knowledge on that subject here.
                      You totally nailed it for me (or at least created a low-temperature, bonded metal-alloy joint), as I was quite unaware of these cored specialist solders. Thanks again.
                      Cheers, Colin
                      #546813
                      Keith Hale
                        @keithhale68713
                        Hi Colin
                        Thank you for your comments. I am pleased that I was able to help. Any time 😀
                        Keith
