Fitting a milling vice to a Sieg C3 lathe
Home › Forums › Manual machine tools › Fitting a milling vice to a Sieg C3 lathe
  • #741043
    Roger Hart
      @rogerhart88496
      I have a Sieg C3 type lathe and picked up a milling vertical slide/vice recently.  This has a hefty 90 bracket and a vertical slide and a vice attached.  A little bit big for the C3 but never mind.
      Firstly,  if I remove the topslide by undoing two allen screws holding the topslide swivel down does a plate under the crosslide swivel stay in place or fall out?  Not a big problem but a nuisance to avoid.
      Secondly the commercial vertical slides look as if they fit in this place,  but it looks a bit too far away from the chuck centreline to be particularly convenient – but saves drilling holes in the crosslide casting.
      I have contemplated buying a spare crosslide casting and modding that if necessary.
      Has anyone any experience or words of advice?
      #741048
        The Sieg one is intended to mount using the two screws that hold the topslide and also has a hole to clear the central pin.
        Plate won’t drop out.
        #741053
          Prepare to be disappointed!  Whilst extraordinary work was done in the past with milling slides on lathes, my experience of one on a mini-lathe was deeply frustrating. Fundamental problem is space, rigidity and movement are all severely restricted such that jobs that are easy on a real mill are downright difficult on a milling slide.
          My slide annoyed me so much I saved up for a mill.
