The Evolution blades are around 25.4mm, so may bushing on other mitre saws. Max speed 3000 rpm.
I got a Rage machine from Screwfix last Saturday. The blade safety mechanism was all bent up and it was impossible to mount the blade. Judging by the metal damage around the blade spindle mounting I summised this had been done at the factory (it had been severely beaten with a hammer). Also I noticed the infeed and outfeed tables and the round rotating table were all at different heights. I took it back and exchanged it.
I got the second machine home on Sunday. The blade fitted perfectly this time. However, the 3 table surfaces were again all at different heights. If I rested a piece of wood both on the infeed table and the rotary table then the wood was not horizontal, The work was inclined up at an angle, because the infeed table was lower than the rotary table by 2mm. The machine clamp only allows clamping to the infeed table so the problem could not be overcome easily. I took it back and go my money back.
I then went to Machine Mart to have a look at the display models. The Evolution tables all exhibited the same problem, to varying degrees,
I bought another make in the end because the 3 surfaces were all at the same height.
I did do a few test cuts with the Rage, but only on wood. The cuts were very good and the machine felt of good quality and had good power. I was impressed by this. It is a shame that the ones I encountered had not seen any quality control. I was in a rush to finish a job and needed a mitre saw straight away, else I would have waited to get a good Rage.
This guy gives some nice advice on choosing a blade (negative rake, triple chip grind) . **LINK**
Steve
