Posted by AdrianR on 16/07/2019 12:39:16:.
One day I am sure I will need to more complicated marking out, then I will buy the proper marking out fluid.
Adrian
For me marking out was very helpful with hand-tools and for manual setting operations like centre-popping ready for the pillar drill.
Now I've got a mill I do much less marking out than before, especially since adding a DRO. Drilling with a mill I don't centre-pop, and – because the work is mounted on a precision table – I usually cut direct from the paper drawings relative to reference points established on the actual work.
Not much need to mark out now, though it does help prevent silly mistakes. For that purpose I often scratch guide marks on odd blobs of felt-tip, but it's not really proper marking out at all. Apart from blobbing, another advantage of felt-tips over proper marking fluid is colours. I have some sort of blind spot causing me to cut mirror-images and colour coding helps reduce blunders.
Marking out might be unfashionable in my workshop only because of the type of work I do. Do others find elaborate marking out useful and if so, what for?
Edited By SillyOldDuffer on 16/07/2019 13:09:51
