Emma Victoria
Emma Victoria
Home › Forums › Beginners questions › Emma Victoria
  • #129162
    Alastair Macpherson
      @alastairmacpherson52003
      I have begun to build an Emma Victoria, my first attempt at loco building. I have finished the chassis frame and am about to start on the axle boxes but am unsure what clearances I should allow between the boxes and horns in both directions. Any advice would be welcome.
      #6866
      Alastair Macpherson
        #129337
        Bill Dawes
          @billdawes
          Hi Alastair, this too is my first loco. Fairly new to ME as well.
          I am just a bit ahead of you at the moment. When I had finished rivetting on the horns I found, that despite taking as much care as I could, the gaps varied on each axle so I measure each one and 'made to fit' I initially allowed a 'few thou' (not very precise I know) and then finished off with a file to get a nice sliding fit.
          I suspect it takes probably a bit more skill than I have at the moment to get a high degree of precision. I noticed at the recent Bristol exhibition that the horns were machined castings which I assume is a more expensive but more precise way of doing it.
          Good luck.
          Bill D.
