Electro etching
Electro etching
Viewing 15 posts - 1 through 15 (of 15 total)
  • #33952
    Peter Ellis 5
      @peterellis5
      Etching a scale around a GHT Pillar Tool Table
      Peter Ellis 5
        @peterellis5
        I have been thinking of Electro etching the 360deg scale around my Pillar Tool Table.
        Does anyone know of a supplier for the masks ?
        Cheers
        Peter
        #581542
        DMB
          @dmb
          Could the masking be done photographically, perhaps using a cheap circular degree perspex disc from W H Smith(?), in the area of items aimed at school usage.
          #581574
          Peter Ellis 5
            @peterellis5
            Thank you, but it needs to be a linear scale, essentially a strip to wrap around the circumference to etch through.
            #581576
            David Noble
              @davidnoble71990
              Would this help?
              Photoetching for sundial makers
              David
              #581600
              Tim Stevens
                @timstevens64731
                I wonder if I am the only one thinking 'What material is going to be etched? – What electrolyte is in mind?'
                But then, we all enjoy a good guessing game now and then.
                Regards, Tim
                #581601
                Peter Ellis 5
                  @peterellis5
                  Thanks David. I enjoyed watching it. I´ve even got Ferric Chloride. I´ḿ familiar with the process and have photo etched in the past. From his comments in the Postscript, it sounds like he is making his own masks.
                  Thanks
                  Peter
                  #581604
                  Peter Ellis 5
                    @peterellis5
                    Posted by Tim Stevens on 21/01/2022 18:49:37:
                    Regards, Tim
                    Given that I mentioned that I was wanting to etch the GHT Pillar Tool table, I assumed that most people knew that these are made of cast iron.
                    #581608
                    David Noble
                      @davidnoble71990
                      Sealing the mask around a curved surface sounds interesting
                      At the risk of being tedious, here is another video that I found helpful with my clocks.
                      David
                      #581619
                      Robert Atkinson 2
                        @robertatkinson2
                        Yuo could use a photo sensitive resist like this:
                        https://uk.farnell.com/kontakt-chemie/positiv-20-200ml/positive-resist-photo-sensitive/dp/801010
                        and use a negative of the sacle to expose it Devlop (in sodium hydroxide/ casutic soda typically) then etch with ferric cloride. Scle cn be printed on clear film in a laser printer.
                        Robert G8RPI.
                        #581699
                        John Rutzen
                          @johnrutzen76569
                          Hi, I've had some success with electro etching nameplates for locos. I use Press n peel blue [ebay]. The print has to be done on a laser printer. The etching is done in copper sulphate solution, I found it best to do it face down so the material etched away falls off. It doesn't take long or much current, I used a small variable power supply. There was a good article about it in MEW some years back.
                          #581751
                          Andy_G
                            @andy_g
                            Posted by Peter Ellis 5 on 21/01/2022 13:26:09:
                            Cheers
                            Peter
                            The guy in the video below uses a vinyl stencil (7:28 if it doesn't go there on its own). I see that there are plenty of places offering a cutting service, but haven't done it myself, so can't make any personal recommendations.
                            #581759
                            Peter Ellis 5
                              @peterellis5
                              Thank you. Yes, I had seen that. The sort of thing I need would be a straight strip, as it goes around the thickness of the table.
                              #581809
                              Andy_G
                                @andy_g
                                I don't think there'd be a problem cutting a long strip (one would need to produce the artwork somehow though). It might be a bit tricky to get the scaling right to exactly match the table circumference. Maybe not so much of an issue if you were only proposing to etch the numerals, but (I think) quite challenging for the graduations.
                                #581816
                                DMB
                                  @dmb
                                  Sorry Peter, mis understood what was required.
                                  Now I do and I would go about in similar fashion to that suggested by Andy G, in that as I have dividing gear, I would engrave the divisions and etch numbers and lettering, thus getting the best of both worlds, in my opinion. Certainly, dividing and engraving with some sort of scratching implement will overcome problem of matching a flat scale to a circumferential position. Etching letters and numbers would create acceptably good appearance.
