Electric motor and control
Home › Forums › General Questions › Electric motor and control
  • #564215
    Stephen Bunch 1
      @stephenbunch1
      Greetings,
      Advice required Electric motor 500 – 750 watt 240volt complete with speed control suitable for Pultra lathe. I would also consider a DC set-up complete with all controls.
      Price is not particularly important but whatever chosen it must be immediately useable…a complete unit ,no messing about.
      Thank you in advance.
      Stephen Bunch
      #28362
      Stephen Bunch 1
        @stephenbunch1
        #564220
        noel shelley
          @noelshelley55608
          500- 750 watt 3ph 240v motor and VFD, Numerous companys supply the complete package ready to run, even ready wired. Should give you all you need or want. Noel.
          #564228
          John Haine
            @johnhaine32865
            Motor unit for Sherline lathe – available as a complete unit I believe.
            #564248
            larry phelan 1
              @larryphelan1
              Ah yes, but no adventure ????cheeky
              #564266
              Mike Poole
                @mikepoole82104
                Have a look at Newton Tesla, the packages have everything done. You will need to fit the motor and pulley for your lathe.
                #564278
                Clive Steer
                  @clivesteer55943
                  I've just fitted a Brushless DC sewing machine motor to my Pultra lathe. I used some of the motor mount parts that came with the complete package at £99. The motor is more noisy than an induction motor but the level of torque and speed stability at low speeds is very good. The Pultra is ideal for having the motor mounted under the lathe but I elected to mount the motor behind the lathe with the controller to the left of the lathe so everything is above the bench. The only custom part I needed to make was a 16cm x 16cm mounting plate with 4 hole in it. Two to mount the plate to the base casting and two for the motor and belt tension adjuster. My plate was 15 mm thick Ali but only because I had some to hand and I'm sure something thinner would be fine. I used a 5mm V belt to link the motor pulley to that of the lathe and the pulley cover provide in the kit was used to guard the belt from stray items.
                  If anyone want to PM me I can send some pictures and meanwhile will try to post them to the site.
                  #564293
                  Trevor Drabble 1
                    @trevordrabble1
                    Stephen , I have a good quality 370 watt VFD which l am looking to sell . If you are interested , please PM me for pics . I've tried recently to enter pics on this site , but afraid l failed miserably . Trevor .
                    #564306
                      Posted by Clive Steer on 25/09/2021 21:07:41:
                      I've just fitted a Brushless DC sewing machine motor to my Pultra lathe. […]
                      That would be useful, Clive
                      Here’s a reminder of how post pictures : **LINK**
                      https://www.model-engineer.co.uk/forums/postings.asp?th=103028&p=1
                      Clive Steer
                        @clivesteer55943
                        Have managed to upload 4 pics of my Pultra with sewing machine motor.
                        #564368
                          That looks tidy, Clive yes
                          Stephen Bunch 1
                            @stephenbunch1
                            Many thanks to all who sent me advice and contacts.
                            I have decided to go the way of Newton Tesla and expect to be making swarf very soon.
                            Thank you
