drill doctor sharpener worth the money?
Home › Forums › Beginners questions › drill doctor sharpener worth the money?
  • #43732
    Ian Welford
      @ianwelford58739
      Got a friend going to the usa in a few months and wondering about a drill doctor drill sharpener. Anyone used one- got any views on it?
      #4774
      Ian Welford
        @ianwelford58739
        drill sharpening
        #43734
        HasBean
          @hasbean
          I have an early version of one
          #44165
          Paul Clapham
            @paulclapham12886
            Hi Ian I have a drill doctor and after a bit of fiddling about with the settings its a great bit of kit.
            Just be aware that the voltage in the USA is 120 volts! this is not a problem as 240v to 120v voltage droppers are available in this country, this is what I use.
            240v drill doctors are available.
            #44171
            Ian COUSINS
              @iancousins37984
              Hi Ian.
              It depends on what one means by “Worth the Money”! After determining my local (Australian) price, I imported a Model 750X from a US discount tool store. I am slightly disappointed by it, as it seems not to approach the claims for precision made in its advertising. As Paul says above, it needs an amount of fiddling to produce acceptable results.There were some helpful tips in “MEW” Number 128.
              I test my drills by drilling into a piece of 3/8″ black steel plate after sharpening, then reversing the drill to see how tightly the parallel shank fits the drilled hole. If it’s a close fit, I deem the drill to be acceptable. I only achieve reliable results with the standard 118 degree point and other settings seem very “hit or miss”.
              It should be kept in mind that the machine uses a very small diameter, diamond-coated wheel, so small adjustments can produce large changes.
              I find it better for diameters between about 3/16″ and 1/2″ and the results for 1/8″ drills are only fair. It is almost useless for 3/32″ drills. The collet drill-holding device is clever but a compromise. The machine’s point splitting function is almost useless.
              Mine is used on my DIY drills and my “rough” ME drills but I do not expect it to produce a point which presents competition to a new, quality drill.
              Cheers!
              Ian
              Edited By Ian COUSINS on 14/10/2009 09:21:09
              #126242
              Elham Koochaknia
                @elhamkoochaknia75568
                I am Looking for a Drill Bit sharpener similar to Drill doctor functions but for bigger drill bits up to size 80 mm. can anyone help?
                #126284
                Tony Jeffree
                  @tonyjeffree56510
                  Posted by Ian Welford on 22/09/2009 21:09:59:
                  I bought a used one on Ebay, complete with the (VHS!) video, and never managed to persuade it to cut a decent point on a drill. After occupying space on my bench for way too long, I sold it on Ebay. Obviously, starting with a new one might be a more rewarding experience, but it isn't an experiment that I would repeat any time soon.
                  Tony
                  #126304
                  Sub Mandrel
                    @submandrel
                    I have a much more basic Plasplugs 4 in 1 sharpener, it requires a fair bit of care and patcience but works on twist drills.
                    As an unused £4 bootsale bargain I'd say it was worth every penny
