For a while I’ve been buying my drill bits from Warco, and I found them to produce a hole size that was pretty much spot on. My definition of being spot on being a nice sliding fit with ground silver steel of the same diameter. Drill bits I’ve bought from RDG tools, Amadeal, and Arc Euro trade were all just as good.
I then switched to one of the bigger ebay suppliers and bought sets of ‘precision ground TIN’ and results are all over the place. Price wise, and in packs of 10 they were maybe 2/3 the price of the suppliers mentioned above. Over a cross section of sizes, A 4mm ebay drill is producing a hole size of 4.32mm, a 6 mm drill 5.95mm, and 8mm drills were banana shaped.
Granted I can use a reamer for accuracy, but I’m curious to know if the usual suspects that we buy our stuff from are all particularly good, or is my ebay supplier particularly bad. Maybe it’s just a case of you get what you pay for.
I’m also curios to know what people deem acceptable hole size accuracy ?
The results are the same for drilling in either the mill or the lathe, with different chucks used for both, across a good sample of the packs of 10 drill bits, and results measured in aluminum, brass, and steel. Returning to the above ‘engineering’ suppliers with my old drill bits produces the same excellent results, so nothing has gone wrong in my machines.
David
