Thanks for the responses. Yes it is 1/4″ to transmit 1/3HP if I recall correctly. The existing belt is to most intents ‘unbreakable’ and one thought is to fit a jockey pulley to lose some length, but it would have to be supported off the bottom plate of the belt guard (an alloy casting) and would still potentially leave a problem in future when (if?) the belt ultimately fails.
I am currently using 6mm green belt bought at Harrogate last year, I think it is Swiss made. It runs in semi-circular grooved pulleys but the weak point seems to be the heat welded join, though I have managed to get a satisfactory result that has lasted several months now providing I don’t try and take more than a light cut. It is a light machine but is capable of more than I dare subject the belt too.
The hollow belt with fasteners is an option but will the join cause noise and vibration? The smallest pulleys are quite small, maybe 1.5″ – leather with fasteners is not preferred for the same reason.
I have seen it stated that the original belts were by a firm called Dawsons and that they no longer have the moulds. Re-machining to suit Poly-V belt (say only 3 wide) may be an option. Anybody tried that route?
Adrian
