Am applying to the forum for some guidance…
For conventional grinding, I have always used a W36 to shape HSS tools and 60 or 80 grit to finish and recently a 60 green grit to shape/sharpen brazed carbide. Sometimes, a tool may get a final hone with an appropriate grade of slipstone. I use the usual budget style 3000 rpm grinder with a collection of various rests and guides etc.
This system has worked for me for a long time, but in order to move with the times, I was thinking of trying an EP diamond wheel (now they are affordable) to see if I could improve my efforts on the brazed carbide tools
So, my question is what would be appropriate grain sizes for EP diamond wheels for use on the hobby grinder ( was thinking of getting 80 and 120 grits for finish grinding). Is there any point going any finer?
Can you use the 40 grit ones for shaping, or does the abrasive just get ripped of the substrate on HSS?
Secondly, are the diamond impregnated resin wheels any better than EP diamond? Also, most of the affordable impregnated resin wheels seem to be in the fine range of 150 to 180 grit. Are these any use for sharpening, or are they only for final honing and polishing up of carbide inserts?
When they get clogged, how do you clean diamond wheels, ultrasonic cleaner, acid, some other method?
Ta.
