Plans for a new workshop are afoot but I have a request for help.
The part of the garden where I would like to build the workshop is bounded on three sides – raised patio (left), neighbour's garage (rear) and boundary fence (right). The boundary fence is the low point so that is my datum to comply with planning. The garage has its eaves at 2.45m so I don't want to go above that (planning restriction is 2.5m anyway). Maximum size would be 16 x 10 ft to stay within planning rules and not require an application.
The "plot" is 16 ft wide across the garage between the patio and the boundary fence. I could come into the garden as far as I like but more than 10 ft will be imposing. I plan to screen the workshop with decorative fencing to appease SWMBO
How can I maximise the size of workshop I could build?
If I need to fix external cladding from the outside onto the frame then I lose space by requiring space between the workshop and the garage and the boundary fence, probably 2 ft per side.
Or is there a way to fabricate the walls and put them in place then add the frame or bracing afterwards? I would have clear access from the front and left (patio)
Any thoughts?
