Denham Junior Mk2 Drawbar
Home Forums Manual machine tools Denham Junior Mk2 Drawbar
  • #13450
    Roger Clark
      @rogerclark
      Assuming it uses 5C collets
      Roger Clark
        @rogerclark
        Can anyone tell me if the lathe uses 5C collets or if not what the taper is in the spindle please?
        I would like to use a centre but don't know how to do it in this lathe.
        I'm thinking if it uses collets then I could machine up a drawbar and use a collet to hold a centre. Of course I would like a kind person to give me the dimensions of said drawbar to do this. wink
        Can anyone help please?
        Roger
        #399927
        Roger Clark
          @rogerclark
          Ok they are not 5C collets, way too big, the spindle bore is 0.75" with a slightly larger taper so how can I find what taper this is?
          Anyone?
          Roger
          #399934
          ega
            @ega
            A quick look at lathes.co.uk did not reveal the answer to your question. Why not try offering up, say, a 3MT?
            #399935
            Brian H
              @brianh50089
              Roger, cannot help with this specifically but http://www.lathes.co.uk/denham/ may. They also say that they have some literature.
              #399937
              Roger Clark
                @rogerclark
                Thanks Brian, been there, got manual but no info contained therein. It's probably the first items to be discarded, damaged, not replaced and so forgotten in the annals of time. sad
                Roger
                #399938
                Brian H
                  @brianh50089
                  Roger, the 3 MT suggestion is a good one, the small end of one is just over that for 3 MT.
                  #399942
                  Roger Clark
                    @rogerclark
                    A good idea but I only have 1 &2 mt and the main tapers are R8, will try to beg, borrow or acquire one to try
                    #399960
                    John Baguley
                      @johnbaguley78655
                      Mine's 3MT. Just been and checked smiley
                      ega
                        @ega
                        PS You could always chuck a piece of scrap and turn a centre on that with the driving dog then running against the chuck jaw.
                        #399972
                        Roger Clark
                          @rogerclark
                          Posted by John Baguley on 12/03/2019 17:28:22:
                          Cheers John, I'll order up a 3MT dead centre then.
                          Roger
                          #399973
                          Roger Clark
                            @rogerclark
                            Posted by ega on 12/03/2019 17:31:00:
                            Having the chuck on will take too much travel off.
                            Roger
