Deckel FP1
Deckel FP1
Home Forums Beginners questions Deckel FP1
  • #85870
    Ian Loft
      @ianloft27442
      I have purchased a second hand Deckel which is 380 volt 3 phase and I wonder if anyone can advise if it is possible to run this unit from an appropriate inverter providing 220 volt 3 phase?
      Ian Loft
        @ianloft27442
        Universal milling machine with Active position readout unit
        #85873
        Richard Parsons
          @richardparsons61721
          Ian Hi You have a 'Continental' 3 phase unit. It is marked 380 Volts 3 Phase. On the Continong they calculate thr RMS voltage slightly different to us. We will say 440 Volts 3 phase they will say 380 volts 3 phase. I know it is confusing but It is the same blooming stuff.
          Your single phase is 240 Volt over here is 230 Volts.
          Best regards
          Dick
          #85886
          Gray62
            @gray62
            Hi Ian, you will need to change the motor from star to delta wiring to runn off a 220v inverter. Check if your terminal box has the appropriate jumper strips, if you're not sure what to look for, look here: http://www.drivesdirect.co.uk/how_to_choose.htm
            #85956
            Ian S C
              @iansc
              Often here motors have on them 380V/440V, 240V/220V. The single phase motor on my lathe has tappings labled 210V, 220V,230V,240V. Ian S C
