Posted by Vic on 18/10/2018 09:27:32:
I often seem to need to drill holes or drill and tap along a round bar or thick tube, what’s the best way of deburing the hole to get the best appearance? …
I’m using M6 most recently. TIA.
Posted by Vic on 12/11/2018 09:35:19:
The bar diameter varies from about 12 – 25 mm. For my immediate purposes I’ve managed to get a centre drill with a 5mm tip so this will be perfect for tapped M6 holes. The Noga set looks good but I can’t justify the price. I should perhaps look into a single tool from Noga that might suffice.
What kind of volume/frequency are you looking at? How steady are your hands and how is your vision?
An approach for Cross Hole Deburring (hint: search topic) that seems to be common amongst the CNC Automation crowd is the use of a ball-shaped burr or lollipop cutter.
XEBEC Cross-hole Debur (How the CNC guys do it)
https://m.youtube.com/watch?v=55xCGNKxiTQ
If inclined, that approach could be mimicked manually with a Dremel or similar tool. Dremel offers 1/8" Round Carbide Cutters, as well as 1/4 × 3/16 Carbide Cutters in single and double cut. Other vendors will have different options to choose from. You might persuade your dentist to save cast-offs in smaller sizes.
Orbitool in a cordless handheld grinder https://m.youtube.com/watch?v=U6TIqlekuRU
