DC Lathe and Mill drive motors
Home › Forums › Manual machine tools › DC Lathe and Mill drive motors
  • #180809
    ray jones 1
      @rayjones1
      Many Manufactures of Lathes and Small Mills, such as Warco, Toolco, Amadeal and others use a variety DC motors each with variable electronic speed control… The Motor speed variation is achieved by using Pulse Width Modulators… Do the DC motors and/or brushes need much maintenance? Is this system reliable?? Thank You
      #12430
      ray jones 1
        @rayjones1
        #180810
        norman valentine
          @normanvalentine78682
          I can't give much history but my home built mill with !/2HP 180v DC motor powered by a cheap Chinese speed controller does everything that I want.
          #180812
          Les Jones 1
            @lesjones1
            Any motor with brushes will need them checking and replacing from time to time. It would also be worth cleaning out the carbon dust that results from the brushes wearing.
            Les.
            #180823
              The brushless motors have 'sealed for life bearings' and should need no maintenance. As Les says, cleaning out carbon dust from brushed motors from time to time is a good idea. The brushes need to e watched for wear.
                Had an X3 mill since 2007 and never touched the motor, Warco 280 lathe for about 5 yrs and just one brush set changed fairly early on. Both brushed DC motors
                J
                #180902
                oldvelo
                  @oldvelo
                  Hi Ray
                  As Les says an occasional check and clean out is all that is required.
                  In a home workshop they will not be run for an excessive amount of time in a year.
                  Eric
                  #180910
                    I burnt out two mini-lathe brushed motors through prolonged lathe-abuse and a third spare I ought from a 'nice old gent'' turned out to have two blown windings.
                    That's not to say brushed motors are no good – the brushless motor o my X2 mill is fine – but I tend to run it faster.
                    The problem is that he mechanical capabilities of a mini-lathe are greater than those of the standard brushed motors, and I like to work the lathe harder than it ought to be, and when this means larger diameters it means brushed motor working hard and slow – which is a recipe for overheating.
                    I would, however, definitely go brushless in the future, even at significant extra cost.
                    blowlamp
                      @blowlamp
                      Posted by Neil Wyatt on 23/02/2015 17:52:52:
                      This is a similar motor & controller to the one I fitted to my Mini-Lathe.
                      There is phenomenal amount of torque when compared to the original motor fitted to this lathe.
                      Martin.
                      #180976
                      oldvelo
                        @oldvelo
                        Hi
                        A computer cooling fan fitted to the end of the motor run from a 12 volt "Plug Pack" power supply will help keep the motor a lot cooler on low speed and high loading.
                        As Blowlamp suggests a bigger horse power motor will give much better performance over the stock standard motor.
                        This review may be of interest to anyone.
                        http://www.mini-lathe.com/mini_lathe/reviews/sieg_sc2/sc2.htm#Update 09/10/09.
                        Thank's to Frank Hoose and his excellent website.
                        Eric
                        #180978
                        Danny M2Z
                          @dannym2z
                          On mine (brushed), lathe stops and the yellow light comes on. I call it the 'stupid light' as invariably I have attempted something stupid. Lol, it is quite an invaluable feature of the mini-lathe.
                          * Danny M *
                          #180980
                            Posted by blowlamp on 23/02/2015 18:16:28:
                            That's a useful-looking set, Martin
                            Thanks for the link.
                            blowlamp
                              @blowlamp
                              Posted by Michael Gilligan on 24/02/2015 08:01:21:
                              There is a phenomenal amount of torque when compared to the original motor fitted to this lathe.
                              They're great, they are BLDC motors and very similar in capability to those fitted to Hi-Torque Mini-Lathes. teeth 2
                              Good price too!
                              Martin.
                              #180998
                              Michael Cox 1
                                @michaelcox1
                                Posted by oldvelo on 24/02/2015 03:07:50
                                I have done this. It certainly help when turning at low speed, details are here:
                                http://mikesworkshop.weebly.com/lathe-motor-cooling.html
                                #181021
                                JES
                                  @jes
                                  The Motor and controller that "blowlamp" mentioned in his post. Would it be suitable for a ML 7?
                                  I ask as I am thinking of going for a variable speed drive for my venerated machine, any comments would be appreciated
                                  JES
                                  #181022
                                  Les Jones 1
                                    @lesjones1
                                    Hi JES,
                                    Note that the motor is rated at up to 4500 RPM I imagine the 3/4 HP rating will be at this speed. I also imagine it would give constant torque below this speed so that if you used the same drive ratio as you would on a 1400 RPM motor when its was running at 1400 RPM it would only produce about 1/4 HP You would need to check with the supplier on the motor characteristics. If you change the drive ratio to allow it to be used up to its maximum speed then I think it would work well.
                                    Les.
                                    #181025
                                      As Les says, it may be a bit small to run an ML7 satisfactorily, I'd be inclined to use a 1400 rpm three-phasemotor and a VFD, especially as this solution has given very may people excellent results.
                                      Martin's suggestion is very tempting for smaller high-speed machines though.
                                        It's worth noting that the same supplier also has a 1HP version available.
                                          Posted by Les Jones 1 on 24/02/2015 15:12:40:
                                          That could be very easily configured using Poly-V
                                          … definitely a tempting possibility.
                                          blowlamp
                                            @blowlamp
                                            Anyone interested in the conversion should take a shufti in my album. There are five pictures in there that give an idea about how it all got rearranged. smiley
                                            Martin.
