Darex end mill sharpener
Home › Forums › Workshop Tools and Tooling › Darex end mill sharpener
  • #18846
    Tractor man
      @tractorman
      #340843
      Tractor man
        @tractorman
        Hi all.
        Bought a Darex end mill sharpener that needs a little work.
        It’s missing the stylus assembly that supports the flutes so that they follow the grind wheel. It has an air bearing spindle which allows low friction movement of the tool being ground. Should be a useful tool for the shop. Does anyone use one in their work?
        Best regards Mick
        #340844
        Tractor man
          @tractorman
          By the way photos are in my albums rather than try to post here.
          #342166
          Tractor man
            @tractorman
            Darex are still in business and doing spares for the E90.
            Managed to order replacement parts for the flute support so i can have it up and running soon.
            #342216
            Chris Evans 6
              @chrisevans6
              I used one on a regular basis at one place I worked. A good bit of kit, we made follow stylus out of old hacksaw blades for ours. One tip is to make sure the air supply is dry, that sliding spindle does not like wet air.
              #342304
              Tractor man
                @tractorman
                Hi Chris.
                It has an air drier in line so things while be ok. The bearing shaft is a bit scoured but still runs smoothly. A new one was ?450 so I will persevere with the one I have.
                The follow stylus is carbide and ?70 so I’m making my own as you said.
                The handbook says an hour of practice will have an operator to a good level.of skill,did you find it easy to use?
                I’m hoping to be able to tidy up my cutters before they get damaged rather than try to resharpen a cutter that’s closed.
                Best regards Mick
                #342318
                Chris Evans 6
                  @chrisevans6
                  Hi Mick, yes very easy to use the Darex. I had prior to this used many differing cutter grinders so no real learning curve for me.
                  #345054
                  Tractor man
                    @tractorman
                    New parts arrived from America and it works fantastically .
                    Best regards Mick
                    #345056
                    Chris Evans 6
                      @chrisevans6
                      Great news, I remember the one I used to use. We mounted it on to a bench because the supplied pressed steel legs where a bit flimsy, otherwise all good.
