D1-3 compatibility
D1-3 compatibility
Home Forums Manual machine tools D1-3 compatibility
Viewing 25 posts - 1 through 25 (of 43 total)
  • #12325
      CamLock, or is there an alternative ? …
        Can anyone please tell me the most compact lathe which would accept a D1-3 chuck? … either a proper CamLock fitting, or is there an alternative that keeps the big tapered nose, but replaces the lock-pins with bolts ??
        Thanks
        Bob Brown 1
          @bobbrown1
          I doubt there are any "compact" lathes that have a D1-3 headstock. What are you trying to achieve?
          #159869
          Nick_G
            @nick_g
            I know the Harrison M250 has a D1-3 headstock and this range of Boxfords does **LINK**
            I suppose it depends upon your definition of 'compact'.? I have one of those Boxfords which for model engineering could not be considered compact. But a friend of mine who runs a machine shop considers it to be a baby lathe.
            Nick
            #159874
            John Stevenson 1
              @johnstevenson1
              chipmaster ?
              #159877
                The 7 & 8 series Emco lathes have a tapered nose but use studs and nuts rather than cams if its the short taper fitting you are after.
                Prazimat also has the short taper but a keyhole type flange which just needs the nuts nipping up
                Edited By JasonB on 06/08/2014 11:56:29
                #159878
                  Posted by Bob Brown 1 on 06/08/2014 11:07:43:
                  Bob,
                  What I am trying to achieve, is the use of a Burnerd MultiSze Collet Chuch [which I already own] in the small space which I have available.
                  If I had the space, I would probably just buy a Chipmaster, or a Kerry [both of which I have used and liked], but I do not have the space, and I only need a small "working envelope" … i.e. I don't want, or need a big machine, but I do want to use this chuck.
                  P.S. … I may consider buying just a headstock, and building a "Bitza"
                  #159879
                    Posted by John Stevenson on 06/08/2014 11:43:24:
                    chipmaster ?
                    John,
                    That would probably be my first choice, but I don't have the space.
                    Thanks
                      Posted by JasonB on 06/08/2014 11:52:37:
                      Thanks, Jason
                      I will investigate.
                        Just saw your other post, its a different taper so no use to you
                        #159883
                          Posted by Nick_G on 06/08/2014 11:15:22:
                          Nick
                          Thanks, Nick
                          I think I've covered "compact" in my reply to Bob. … If it would just clear the Chuck body, and take [say] 12" between the face of the collet and a tailstock centre; that would be plenty big enough.
                          MichaelG. … [just looking for inspiration]
                          #159884
                            Posted by JasonB on 06/08/2014 11:59:43:
                            Thanks anyway.
                            #159885
                            Bob Brown 1
                              @bobbrown1
                              I think you best bet may be to make up an adapter plate that once you remove the locking pins allows the chuck to be mounted/bolted on one of the compact lathe back plates, blanks are cheap enough.
                              Details of the D3-1 mount is here **LINK**
                              Bob
                              Edited By Bob Brown 1 on 06/08/2014 12:40:01
                              #159890
                                Sorry, Bob, but that is not what I want.
                                I want a proper headstock spindle in big bearings, that is made to the appropriate level of precision.
                                Bob Brown 1
                                  @bobbrown1
                                  How much space are we talking about?
                                  #159893
                                  John Stevenson 1
                                    @johnstevenson1
                                    Posted by Michael Gilligan on 06/08/2014 11:55:33:
                                    Bob,
                                    Surely a bit like finding a crutch in the gutter and breaking your leg so as to make full use of it ?
                                    #159894
                                    Old School
                                      @oldschool
                                      Myford 254 but not really a compact
                                      #159895
                                        A Bantam probably has a slightly smaller footprint than a chipmaster as the stand goes straight down rather than flaring out
                                        #159897
                                          Posted by Michael Gilligan on 06/08/2014 10:57:34:
                                          Bob,
                                          Space is at an absolute premium… which is why I specifically asked regarding "the most compact lathe which would accept a D1-3 chuck"
                                          This chuck has lain unused for over twenty years and [prompted by my discussions with Nick, on another thread], I have finally decided to find a way of using it.
                                          Nick_G
                                            @nick_g
                                            Posted by Michael Gilligan on 06/08/2014 13:20:19:
                                            I get the blame for everything.!!!! devil
                                            Why should here be any different.? cheeky
                                            Nick winkwinkwink
                                            #159899
                                              Posted by John Stevenson on 06/08/2014 13:11:40
                                              Quite possibly, John
                                              … or maybe like making a Buell because you had a Harley Davidson engine available?
                                              [feel free to subsitute other engine/frame combinations according to taste]
                                                Nick,
                                                star
                                                You were the spark of inspiration to get on and do something with my chuck !!
                                                Very positive … at least, I thought so until I started this thread.
                                                Gary Wooding
                                                  @garywooding25363
                                                  I used to have a Boxford BUD that had a Burnerd lever-operated Multisize collet chuck. I replaced the lathe with one that has a D1-3 spindle, but kept the collet chuck that, alas, no longer fits.
                                                  If you have a D1-3 collet chuck and need one that fits a Boxford AUD, BUD, or CUD, then maybe we can trade?
                                                  Gary
                                                  #159903
                                                  Bob Brown 1
                                                    @bobbrown1
                                                    I did not read the original question correctly, so I would think a short bed 20" Colchester Bantam or a Harrison M250 is probably going to be the smallest.
                                                    Edited By Bob Brown 1 on 06/08/2014 14:09:29
                                                    #159905
                                                    John McNamara
                                                      @johnmcnamara74883
                                                      Hi Michael
                                                      My Lathe a Heidenreich and Harbeck 20Ro uses a Din 55027/5 spindle nose. This is basically the same as a Din 55029 (D1) spindle nose but the chuck has studs with nuts that attach through keyholes in a rotating bayonet ring instead of the cams on a D1.
                                                      This link may come in handy for you.
