Cutting the centre out of a solid workpiece
Home Forums Beginners questions Cutting the centre out of a solid workpiece
  • #120444
    JamesF
      @jamesf
      I have a block of aluminium about 1/2" thick and 2 1/2" square. I'd like to cut a 2" hole in the centre so I can slide a tube through the block.
      Is there a way to do that without turning the entire centre into swarf?
      James
      #6723
      JamesF
        @jamesf
        #120445
        Clive Hartland
          @clivehartland94829
          4 Jaw chuck and center in the lathe and grind a tool like a parting tool with a radius to trepanne through the Alu. Do it slow and sure and use a cutting fluid.
          #120447
          Les Jones 1
            @lesjones1
            Hi James,
            I would suggest using a hole saw. Use the next size down from 2" / 50 mm which will probably be 44 mm then bore out to size. You will probably be able to avoid using the pilot drill if you do it in a lathe or mill. As a coincidence today I did this cutting a hole and a half hole in some 50 mm steel tube to make a T piece.
            Les.
            Edited By Les Jones 1 on 22/05/2013 16:44:56
            #120448
              Yes as Clive says you can trepanne the middle out, for safety I tend to go in from both sides and leave about 0.010"- 0.020" of material, then take the work out of the chuck rest over an open vice and a sharp blow with a hammer will break out the middle
              Edited By JasonB on 22/05/2013 16:48:20
              #120451
              Clive Foster
                @clivefoster55965
                Check how well the material machines first. If its a decently behaved alloy then trepanning or hole saw will work fine. If its pure aluminium or one of the ill mannered alloys that share the sticky, gummy, "build up on the tip as soon as look at you" characteristics of the pure stuff accepting the waste and mess of turning to swarf may be the sensible option. Even if you have a suitable rotary table and set-up stuff drilling a ring of holes is hardly worth the effort.
                First steps in trepanning go a lot easier with something well behaved, OK true of everything but more so in this case. I frequently use the hole saw method but last week lost a tooth from a brand new Starrett holesaw, which promply wrecked the rest, due to assuming the scrapped component source meant well behaved material.
                Whether hole saw or trepan Jasons advice to go from both sides is good. If hole sawing remember you can only go about half a tooth deep before having to withdraw and scrub out the chips. Need a top brand holesaw. El cheapos will melt thier teeth on this sort of deep job and, probably, be so far out of round that they jam.
                I'd probably just drill 6 or 8 half inch holes in a suitable circle and whack a chisel through the left behind webs. Sometimes crude really is all you need.
                #120461
                Another JohnS
                  @anotherjohns
                  DO NOT try and keep the centre material when doing this machining on a CNC milling machine, as, from my experience last weekend, the centre pip tends to bounce around after separating from the main bit, and gets jammed between cutter and workpiece, which tends to do NOT good things!
                  I ended up sacrificing the bit of material in the centre; saved frayed nerves and milling cutters.
                  (Yes, I should have thought of this "loose pip of material" when programming my CNC mill…)
                  Another JohnS.
                  #120464
                  Andyf
                    @andyf
                    I've used both hole saws and trepanning tools. The saw was easier, though it creates an annular channel which is hard to keep clear of swarf if done in a vertical miller/drill. The trepanning was done on the faceplate, with sacrificial backing, and the trick seemed to be to get almost there, leaving a thin web of material so the central disc could be broken/levered out while the job was still mounted, to preserve concentricity for further operations.
                    Andy
                    #120466
                    JamesF
                      @jamesf
                      My concern with trepanning was that the tool would rub on the workpiece and I wouldn't be able to get it shaped enough not to without weaking it too much. Sounds like I should have a go anyhow.
                      James
                      #120475
                      Phil H 1
                        @philh1
                        James,
                        Trepanning is fine provided you grind the correct front and side clearances on the tool because your are approaching a flat workpiece etc.
                        Yes use reduced speed but don't go overboard. I remember a set of about 20 apprentices (I was one of them) trepanning an 8" diameter hole in a 3/4" thick steel plate. Most of the ones that lost the tools were running too slowly.
                        You can usually tell when the cutting tool is not going to take it when you start the cutting. If it starts to rub something is usually not right with the tool setting.
                        PhilH
